2014-07-22T12:13:28+00:00
2014-07-19T23:25:46+00:00
Hi jiachengguo,
  2. Select Settings
  3. Select Control Panel
  4. Select Power options
  7. Select Yes
  8. Restart your Surface
We are here to help!
Best Wishes,
2014-07-19T17:43:11+00:00
2014-07-19T02:11:55+00:00
Dear Clare,
198 additional answers
    2015-08-31T20:29:00+00:00
    Hey folks.
    Here is the fix:
    Download and install the new Realtek sound driver from here. Its totally working.
    If link not working, go to thispage and accept the terms and download second  blue line 64bit Windows 7/8/8.1/10 drivers.
    With Windows 10, even if you install different version of driver Windows update will replace it with driver provided my Microsoft for Surface Pro 3 (as part of firmware update).
    So, even if you got it fixed with different driver, it will come back once update is installed. (You don't get to choose what to update unless you disable update all together. :( )
    Also, I have tried that same version of driver before and did not fix for me. (At least not on Windows 10 )
    2015-08-31T20:25:29+00:00
    Try this. You won't loose microphone this way.
    Under recording devices right click (or touch and hold) empty space.
    Check "Show Disabled Devices"
    You will see "Stereo Mix" which is disabled.
    Click Properties and and bottom under "Device usage", select "Use this device" to enable.
    Click "OK" and open properties again.
    From here, it is same as for microphone.
    Under levels, bring level down to 0 and/or mute.
    Under listen check "Listen to this device"
    Using internal or external microphone does not matter. What Wildsoldier's method does is keep sound device active. As long as you keep it active one away or the other, it works.
