2014-07-22T12:13:28+00:00
2014-07-19T23:25:46+00:00
Hi jiachengguo,
  2. Select Settings
  3. Select Control Panel
  4. Select Power options
  7. Select Yes
  8. Restart your Surface
We are here to help!
Best Wishes,
2014-07-19T17:43:11+00:00
2014-07-19T02:11:55+00:00
Dear Clare,
198 additional answers
    2015-08-23T02:44:27+00:00
    Fastboot is not the culprit necessarily.  I have hibernate disabled on all my machines (which in turn disables fast boot) and we still see the problem.
    Only reliable fix I've come across that isn't ridiculous (such as playing music all the time) is the workaround posted regarding activating the microphone at 0 volume and muted.  Keeping it "active" in this fashion prevents the system and system interrupt processes from going nuts and killing the fan.
    2015-08-23T02:07:09+00:00
    There is better work around.
    Disable "fastboot" from power options. I found that this will fix the problem with only side effect being not able to use "fastboot" feature. And, since Surface Pro have SSD, it still is quiet fast without fastboot.
    I believe there is some issue with driver and fastboot (which saves kernel data from RAM to HDD before shutting down for faster boot).
    I wrote detailed information about this, but moderator spited my post from this thread and sent over to Window 10 category.
    Moderator have moved and merged my post and new thread I started in Windows 10 in way it is hard to find. It is almost as if moderator doesn't want this information to be found. :(
    More info at below link
    http://answers.microsoft.com/en-us/windows/forum/windows_10-desktop/high-cpu-usage-on-surface-pro-3-after-installing/0f80477a-baf6-4877-a0c1-bee3a31e3764
    Check my post this page. (This was new thread I started, that got merged into different thread)
    http://answers.microsoft.com/en-us/surface/forum/surfpro3-surfusingwin10/high-cpu-usage/ad08fd46-5055-4695-891d-9a7415012dbd?page=2
