2014-07-22T12:13:28+00:00
2014-07-19T23:25:46+00:00
Hi jiachengguo,
  2. Select Settings
  3. Select Control Panel
  4. Select Power options
  7. Select Yes
  8. Restart your Surface
We are here to help!
Best Wishes,
2014-07-19T17:43:11+00:00
2014-07-19T02:11:55+00:00
Dear Clare,
198 additional answers
  1. Deleted
    2015-07-30T14:29:54+00:00
    Mine started having this problem randomly after working great for months.  I also had this same problem on my SP2 and never found an actual fix for it either... just assumed the SP3 would be fixed. NOT ha
    On mine (SP3/i7/256), when it does it, it's often after a fresh boot or power on, not necessarily after sleep.  Removing it from the dock as well as removing any other USB devices did just seem to stop it, and also I can stop it by playing a song in the music player (or any actual sound actually) but it goes right back to ~20% when I stop playback.
    Very frustrating, Microsoft what is the solution?
    This was the thread back when I had my SP2, nothing ever solved it then, shocked it is still going on:
    http://answers.microsoft.com/en-us/surface/forum/surfpro2-surfupdate/surface-pro-2-high-cpu-on-resume-from-sleep/ebc0ad3d-c9ed-44c1-b6d0-a19335a4e223
