2014-07-22T12:13:28+00:00
2014-07-19T23:25:46+00:00
Hi jiachengguo,
  2. Select Settings
  3. Select Control Panel
  4. Select Power options
  7. Select Yes
  8. Restart your Surface
We are here to help!
Best Wishes,
2014-07-19T17:43:11+00:00
2014-07-19T02:11:55+00:00
Dear Clare,
198 additional answers
    2015-06-28T16:37:27+00:00
    Last firmware update contains new audio driver, but this problem still persist. Anyone tried Win10 preview on Surface Pro 3 to tell if this issue is there or not?
    2015-06-28T12:09:48+00:00
    Working solution - install Windows 8.0 back on it and turn off Windows Updates. :)
