2014-07-22T12:13:28+00:00
2014-07-19T23:25:46+00:00
Hi jiachengguo,
  2. Select Settings
  3. Select Control Panel
  4. Select Power options
  7. Select Yes
  8. Restart your Surface
We are here to help!
Best Wishes,
2014-07-19T17:43:11+00:00
2014-07-19T02:11:55+00:00
Dear Clare,
198 additional answers
    2015-03-31T21:06:35+00:00
    Split from this thread.
    I have a surface pro 3, up to date using windows update with only Microsoft products installed, I also installed chrome.  After the recent updates the battery drain itself in sleep mode almost as fast as being awake.
    After being left in sleep mode overnight and even disabling the ability to wake up with the type cover, the battery will be drained the next morning.
    After contacting MS support it seems to be a standing issue with no solution (MS support was nice and tried to help).
    Has anyone found a way to correct this sleep issue, some enter airplane mode, but that didn't seem to work.
    I don't understand how MS can release updates that cause this issues, which will sacrifice hardware in the long run and not be held liable for them.
    Draining and overheating the battery when asleep in a bag can severely reduce the life of the batter and the device.
    Any suggestions?
    2015-03-30T02:58:55+00:00
    I have few surface pro 3 and i have noticed that even after clean shutdown. when i start the Surface pro again, my CPU up time show me it still running example. some times 20 days,
    How do i fix that please advise
    Thank you
    Miki
