2014-07-22T12:13:28+00:00
2014-07-19T23:25:46+00:00
Hi jiachengguo,
  2. Select Settings
  3. Select Control Panel
  4. Select Power options
  7. Select Yes
  8. Restart your Surface
We are here to help!
Best Wishes,
2014-07-19T17:43:11+00:00
2014-07-19T02:11:55+00:00
Dear Clare,
198 additional answers
    2015-02-12T00:29:37+00:00
    Go here:
    https://home-uat.diagnostics.support.microsoft.com/SelfHelp/
    Sign in with your Microsoft account
    Find the “Windows Performance Diagnostic”.  It’s on page 14 or so.
    Run that on the Surface while the problem is happening (make sure to save the results).
    Susan Bradley will reply shortly and we will open an IT Pro support case. The saved diags can be attached once opened. The right people will be watching thi.
    2015-02-11T21:29:26+00:00
    Alex,
    I sent your post in to an internal contact. There will be some follow up. Stay tuned.
