2014-07-22T12:13:28+00:00
2014-07-19T23:25:46+00:00
Hi jiachengguo,
  2. Select Settings
  3. Select Control Panel
  4. Select Power options
  7. Select Yes
  8. Restart your Surface
We are here to help!
Best Wishes,
2014-07-19T17:43:11+00:00
2014-07-19T02:11:55+00:00
Dear Clare,
198 additional answers
    2015-01-30T16:25:31+00:00
    Here's the fix:
    Disable Sound Card!
    in Control Panel->Device Manager->Sound, video,game controller->realtek audio->disable it
    Yes, this is not perfect any way, it mutes all the sound on your surface. But it saves battery a lot.
    Before Microsoft fix it, we have to carry on.
    Microsoft, Listen, it's definitely related to Sound Card/Driver!
    2015-01-27T08:11:41+00:00
    After several weeks testing on my Surface 2, trying to discover why the battery drains so rapidly on connected standby (sleep) I thought I found the culprit – the microSD card. As a long time Surface RT user I had always left a microSD card permanently connected for extra storage. On my Surface 2 leaving it connected drains the battery at around 2% per hour – which means if left unused it would drain from 100% battery down completely flat in around 2 days – without even touching it!! Here is a battery report:
     But then the issue has started happening again even without the microSD card attached. I’ve tested removing the USB dongle and detaching the touch keyboard and it still drains at around 2% per hour.
    I’m loath to reset my device as it is only a month old – does anyone know what “Fx Devices - Unregistered Device SE” is? It is always the highest in use component during connected standby.
    At that rate of drain it will be flat in two and a half days without being touched once.
    And finally running powercfg -energy finds this issue:
    System Availability Requests:System Required Request
    The device or driver has made a request to prevent the system from automatically entering sleep.
    Requesting Driver Instance nvaenum\nvawave&ds1nvoice\3&3890e16a&0&00
    Requesting Driver Device NVIDIA Tegra Audio
    Which I have googled a bit but haven’t been able to find anything useful.
    Any help or ideas appreciated - unless this is a hardware issue and I should just try and return?
