2014-07-22T12:13:28+00:00
2014-07-19T23:25:46+00:00
Hi jiachengguo,
  2. Select Settings
  3. Select Control Panel
  4. Select Power options
  7. Select Yes
  8. Restart your Surface
We are here to help!
Best Wishes,
2014-07-19T17:43:11+00:00
2014-07-19T02:11:55+00:00
Dear Clare,
198 additional answers
    2015-01-19T02:39:20+00:00
    Hello ChrisG\_NZ
    Thank you.
    Hello all,
    Please ensure you have the latest updates installed and let us know if this continues.
    Best regards
    Hi John1F ,
    It is frustrating that after so many months of updates, the problem is still there (and even worse).
    Please let me repeat the problem:
    After waking up Surface Pro 3 from hibernation, around 20% of CPU is kept occupied by System and System Interrupts for no good reason. The problem is temporarily away, if some music is playing.
    I think the problem has something to do with Realtek high definition audio. If I remember correctly, I was able to solve the problem by rolling back the driver, but after recent updates even the rolling-back doesn't seem to help. For now, to temporarily avoid the problem, I have to stop any firmware update and go back to the old firmware version around the time that SP3 was released.
    Could you please report to Microsoft technical people to solve this problem? It seems that the problem has been ignored by Microsoft, which is really bad!!!
    Thank you!
    2015-01-12T12:16:06+00:00
    It can happen when your device is running out of space. Windows needs at least 20 GB of free space in order not to have this System penalty.
