2014-07-22T12:13:28+00:00
2014-07-19T23:25:46+00:00
Hi jiachengguo,
  2. Select Settings
  3. Select Control Panel
  4. Select Power options
  7. Select Yes
  8. Restart your Surface
We are here to help!
Best Wishes,
2014-07-19T17:43:11+00:00
2014-07-19T02:11:55+00:00
Dear Clare,
198 additional answers
    2015-01-08T11:09:25+00:00
    Well it is better than before,but yeasterday I turnd SP3 to sleep mode, with Type Cover on screen. I wait few minutes to chec if no fans on. After I come back home after an hour I take out total hot back side of device from my bag. Camera was on....
    How could it happen? SP3 turn on camera itself when having Type Cover on Screen.
    Any idea how to solve it?
    2015-01-06T12:17:12+00:00
    ich have the same issue as the others in this thread. If I turn off the music the process "system" in the task manager starts to use ~15% of the CPU load.
    I installed all latest updates. Please fix this bug, microsoft!
