2014-07-22T12:13:28+00:00
2014-07-19T23:25:46+00:00
Hi jiachengguo,
  2. Select Settings
  3. Select Control Panel
  4. Select Power options
  7. Select Yes
  8. Restart your Surface
We are here to help!
Best Wishes,
2014-07-19T17:43:11+00:00
2014-07-19T02:11:55+00:00
Dear Clare,
198 additional answers
    2015-01-05T01:45:54+00:00
    My new i5, 256GB sleeps quite well. I use it about an hour or so a day and leave it on the living room couch for days between charges. I am very careful about what I install and how it's configured. I can easily imagine installing some desktop application that plays hell with the machine's ability to sleep properly.
    Bye.
    2015-01-05T01:33:31+00:00
    I have noticed this issue as well. Only thing I know to do to avoid it is shut it down when it's unplugged and I'm not using it... I really wish the sleep mode was a little better.
