2014-07-22T12:13:28+00:00
2014-07-19T23:25:46+00:00
Hi jiachengguo,
  2. Select Settings
  3. Select Control Panel
  4. Select Power options
  7. Select Yes
  8. Restart your Surface
We are here to help!
Best Wishes,
2014-07-19T17:43:11+00:00
2014-07-19T02:11:55+00:00
Dear Clare,
198 additional answers
    2014-11-17T01:29:40+00:00
    Today the same thing happen, system and system interrupt was consuming cpu usage and this time the surface was NOT connected to the docking station. I had to restart the surface to fix.
    2014-11-15T02:40:44+00:00
    I have exactly the same ISSUE! now I can not bring my SP3 out without the power adapter.
