2014-07-22T12:13:28+00:00
2014-07-19T23:25:46+00:00
Hi jiachengguo,
  2. Select Settings
  3. Select Control Panel
  4. Select Power options
  7. Select Yes
  8. Restart your Surface
We are here to help!
Best Wishes,
2014-07-19T17:43:11+00:00
2014-07-19T02:11:55+00:00
Dear Clare,
198 additional answers
    2014-11-14T20:32:38+00:00
    I have this very same problem ONLY when the SP3 attached to the docking station. After staring up the system process took about 13% from the CPU and the system interrupt - about 8% with nothing else running. All updates as of today installed. It appear also even if you disconnect the Ethernet and the HDMi from the dock. Actually, I found kind of solution, but it's borring. After the start up - just click RESTART. Not shutdown, but restart. After restarting the SP3 - the problem disappear, no matter if you put the SP3 to sleep or not. Until the next shutdown / power up. I hope that Microsoft will fix the issue, as its a shame. But definitely, the problem is related to the docking station drivers or so.
    You are right....I think i'm experience it also only when its connected to the docking station.
    2014-11-14T19:22:11+00:00
