2014-07-22T12:13:28+00:00
2014-07-19T23:25:46+00:00
Hi jiachengguo,
  2. Select Settings
  3. Select Control Panel
  4. Select Power options
  7. Select Yes
  8. Restart your Surface
We are here to help!
Best Wishes,
2014-07-19T17:43:11+00:00
2014-07-19T02:11:55+00:00
Dear Clare,
198 additional answers
    2014-09-26T15:37:18+00:00
    My sentiments are pretty much the same. Frankly, I love the Surface. I think it's far and away one of the best Windows devices on the market, at least it terms of what it could be. However, issues like this are just unacceptable, especially when spanning multiple generations of a product line. This should have been fixed in the Surface 2 Pro, and if not, Microsoft should at the very least sourced different hardware for the Surface 3 to try to sidestep the same issue recurring. Regardless, the worst part of this is the complete lack of attention from Microsoft. I accept that devices and software will have bugs, but I also expect that the vendor will work to eradicate those bugs. Instead, we get no public acknowledgement and virtually no reply, and what reply we do get is little more than brush-offs.
    More to the point, and I shouldn't have to tell Microsoft, of all companies, this, you've explicitly marketed the Surface 3 to the enterprise as a tablet/laptop hybrid you can actually get work done on. My Surface, in fact, was purchase by my organization for me to use for work. If you're going to target enterprise, then you absolutely have to have top-notch support. Again, I shouldn't have to tell Microsoft, of all companies, that.
    2014-09-26T15:31:33+00:00
    good point indeed!
