It still responds.
Surface Pro 4 Pen needs to be re-bluetooth paired after waking up/turning on surface
My surface pro 4 pen needs to be re-paired via bluetooth after the computer has been sleeping/hibernating in order for the eraser button to function when clicked. It still shows up as a connected device in the bluetooth settings, and still writes properly even when the eraser button does not work. After removing the pen from the list of connected devices and re-pairing, everything seems to work properly but this is obviously inconvenient. Thanks for any help you can offer!
Surface | Accessories | Surface Pen
2016-12-09T22:43:40+00:00 -
2016-12-08T06:26:08+00:00 When this problem happens see if the Windows Ink Workspace icon on the taskbar has also stopped responding by clicking it?
2016-12-08T00:32:37+00:00 Thank you for the reply.
- Windows Build: Windows 10 Pro, Version 1607, OS Build 14393.447.
- Yes the new surface is totally up to date with latest firmware according to windows update.
- I am trying to launch OneNote 2016 with the eraser button as well as trying to open snipping tool with the eraser button.
- When I restart the surface, the pen eraser works normally, same as if I re-pair with bluetooth.
For what it's worth, the answer desk representative at the Microsoft store that I went to told me that he has seen this before and that I will need to wait for an update from Microsoft to have it resolved.
2016-11-22T12:19:30+00:00 Well, I just got a brand new SP4 from the Microsoft Store as well as a brand new pen. This combination of hardware has the same exact issue. Is this just a Windows bug ? The only thing common between both these combinations of hardware is the operating system installed on them...
2016-11-19T21:25:58+00:00 So the replacement pen has the same exact issue...extremely frustrating that it still doesn't work after being without a pen for over a week...
Have you tried creating a new login profile? Your current profile could be corrupt. It doesn't matter if the new login is a local or Microsoft account.
