April 11 is the date it will automatically be made available in WU without user interaction (they will start to make it available then, but slowly). If you want it today, after it becomes available, and no, I don't know what time, go to Windows Update, select Good news! The Windows 10 Creators Update is on its way. Want to be one of the first to get it? and Show Me How. The link it opens will change when it is available.
Surface Pro 4 Pen needs to be re-bluetooth paired after waking up/turning on surface
My surface pro 4 pen needs to be re-paired via bluetooth after the computer has been sleeping/hibernating in order for the eraser button to function when clicked. It still shows up as a connected device in the bluetooth settings, and still writes properly even when the eraser button does not work. After removing the pen from the list of connected devices and re-pairing, everything seems to work properly but this is obviously inconvenient. Thanks for any help you can offer!
Surface | Accessories | Surface Pen
2017-04-05T10:14:38+00:00 -
2017-04-05T09:55:29+00:00 Oh Ok. I thought it was April 11
2017-04-05T09:53:18+00:00 the official released version will be available sometime today. you will be able to get it through Windows Update.
2017-04-05T07:00:01+00:00 Is that Insider Version or the full version released to Public?
2017-04-04T12:38:34+00:00 You will be able to download the Creator's Update tomorrow, April 5th.
