Surface 2 pro charger issue
2014-07-21T12:33:24+00:00
I've had my surface for a few months now and, yesterday I left it on the bed while on and charging, due to being  in a rush. One hour later I return and the rectangular charging box is untouchably hot but my surface is still able to charge. I unplug it and let it cool down and as I am about to use it again it still charges normally, a few minutes later I remove it and reinsert and it stops charging. I've tried everything on the help page but still no luck. I know current is passing through because when I plug if in the rectangular box gets warm but as soon as I attach the magnetic connector, no luck! I know it's attached because it's snaps as usual.
2014-07-22T23:26:32+00:00
Hi FatimaSy,
Thank you for reaching out to the Community! We appreciate you taking the time to consult this issue with us. I’m sorry to hear that your Surface is not charging properly. I can tell you are worried about this situation and it is completely understandable. Please know we will do our best to help and guide you in the right direction.
First, please try to verify if the problem is with the Surface or the adapter.  Check from different outlets and locations. Take a look at the charging port and the tip of the adapter, see if there is any debris or corrosion. If you can, try your charger with a different Surface, and a different charger with yours. If you can get your charger to work with a different device, the problem may be with your Surface. If your Surface starts taking a charge from a different charger, your charger may be malfunctioning.
Second, we suggest you try a two button restart (only useable on Pro and Pro2 devices):
  • Power off the Surface Pro
  • Hold Volume Up and the Power button for 10 seconds
  • Release buttons
  • Wait 5-10 seconds
  • Power on the Surface
Additionally, we also suggest you follow the troubleshooting steps mentioned in the next support article:
•Before you begin
•Solution 1: Remove and reconnect the power supply
•Solution 2: Check the battery charging status
•Solution 3: Restart Surface
•Solution 4: Two-button shutdown (Surface Pro models only)
If the issue persists after trying the steps mentioned above we suggest you contact Technical Support by visiting our Self Service Center here or contact Support **here**.
We hope this information proves useful. Keep us posted!
We are always here to help!
Best Wishes,
2013-11-04T05:05:26+00:00
i uninstalled the battery drivers from the device manager, shut down my surface and unplugged it for around 15 minutes. i plugged it back in and left it turned off for about another 15 minutes. i turned it back on and it was fully charged. i was thinking it may have just been some sort of display error, but the machine was shutting down whenever i would unplug it, so i don't know. hopefully that problem is solved.
the touchpad is still sketchy at times, however. :/
2014-07-23T17:53:44+00:00
Hi FatimaSy,
Thanks for your kind and prompt reply!
If your Surface starts taking a charge from a different charger, your charger may be malfunctioning indeed. Now, if your charger works with a different Surface, the problem may be with your Surface.
You might want to try visiting the nearest Microsoft Store in your area, in order to test this. If this is not possible for you, the next step would be visiting our Self Service Center here or contacting Technical Support **here**.
We hope this helps!
Best Wishes,
84 additional answers
    2013-12-18T18:26:59+00:00
    This solution worked flawlessly. There was actually a stuck update which appears to cause this to happen. This happened once before but at that time the machine would not even turn on as it thought the battery was dead. Spoke with MS tech support (actually an American) and she pointed out that that was an issue. She explained to me how to do a "hard" reboot which took care of the problem that time. Not something you want to do with anything you want to do with anything below a Surface Pro 2 128 though.
    I had the same problem as of 12/15 starting about 23:50 (nearly midnight) using the powercfg /batteryreport commandline tool to look at history of charge and discharge.
    http://www.hanselman.com/blog/PowerCfgTheHiddenEnergyAndBatteryToolForWindowsYoureNotUsing.aspx
    I also noticed that the last firmware install had failed in my update history, and also that, although I know it had been installing updates, the update history shown in the new "Metro" update history (as opposed to using the control panel item) showed no updates since November 2013.
    I ran the windows update troubleshooter app here:
    http://windows.microsoft.com/en-US/windows7/Open-the-Windows-Update-troubleshooter
    This found two issues with the update database, and said that it fixed them.
    After it installed some updates (which did not show in the history, but did prompt me to reboot) rebooting, I notice that it is now charging.
    I also tried the suggestion here:
    http://answers.microsoft.com/en-us/surface/forum/surfpro2-surfhardware/surface-2-pro-plugged-in-not-charging/373cf050-4b10-49b5-88d0-d64970820029
    Somehow a combination of these things worked for me as of this morning.
    2013-12-19T16:57:18+00:00
    Mine is doing the same thing. I've only had the Surface Pro2 128gb for about 3 weeks. The battery has been great up till the last 2 days. I have charged it for the last 3hrs in sleep mode. When it began charging it was at 35%, now 3hrs later when I checked on it, it said "20% plugged in, not charging". I shut it completely down while unplugged, turned it on and it says 20%. Now I switched to a different outlet, have it completely shut down and plugged in. I'm hoping this works. If it doesn't and it leads to me to have to buy a new battery, I think that is absolutely wrong of Microsoft to sell it with a faulty battery, and I will feel taken advantage of with having to spend more money to them for a new battery. You would think the battery would last at least 6 months to a year before going kaput. Sitting here patiently frustrated with fingers crossed.
