June 2021 Firmware Update for Surface Laptop 3 gave rise to USB C & cannot-shut-down problems and many more
2021-07-02T07:52:18+00:00
After applied the June 2021 Firmware Update for Surface Laptop 3, this issue occurs:
  1. At the first time plugging a External SSD into USB-C port, it works fine. But when you click Safely Remove Hardware in notification area (but keep the device plugged), the Device Manager shows that the Storage Controller of the device got something wrong.
  2. After pulling off the external SSD, any other device doesn't work USB C port; sometimes the USB A port fails too. Device Manager reports a Unknown USB Device (Port Reset Failed), with an error code 43. Windows Hello Camera might fail because of this.
  3. Now, the computer cannot manage to shut down or reboot. After the "Shutting Down/Restarting" mono-colour screen disappears and the monitor turns off, the fans keep rotating and the back-light of keyboard is still on. One can only force the laptop to shut down by long pressing the power button.
  4. After re-start the computer, problems can reoccur following 1. to 3.
By the way, this error seems making the computer fail to enter hibernation from sleep, which induces heating of the computer in backpack and extreme battery drain.
On Reddit there are lots of report on similar issues:
Surface Laptop 3 not shutting down properly and battery draining a lot during sleep
Surface Laptop 3 battery drain after shut down
SL3 is overheating in my backpack, even when the device is turned off. What is going on?
Also, on Microsoft Forum:
Surface laptop 3 hot and won't turn on
Battery drain during sleep
Surface Laptop 3 does not completely shutdown.
I've tried reset my computer, which does no help. I do hope Microsoft can handle this issue as soon as possible.
Update on 24 July 2021:
After installing the 23 July 2021 updates](https://support.microsoft.com/en-us/surface/surface-laptop-3-update-history-7471eff4-8de2-1616-5b7b-241e28c2236b "https://support.microsoft.com/en-us/surface/surface-laptop-3-update-history-7471eff4-8de2-1616-5b7b-241e28c2236b"), one of which (Surface - System - 14.502.139.0) claims to "improves USBC performance", the same issue can be reproduced, as pointed out by @[JDPurcell2 and @Hanxxxx
Update on 3 Sept 2021:
I'm elated to share that after the 31 Aug 2021 Updates, which "addresses the system hang and shutdown issue", my USB-C port works well.
I've tested it 3 times, and then the Laptop can restart normally, after which the USB-C port still works normally.
Surface | Surface Laptop | USB-C
2021-07-19T17:06:12+00:00
Updated 9/1/2021 -
Thank you for reporting the issue. A fix is available through Windows Update.  For more information about updates for your Surface available through Windows Update see the Surface Laptop 3 update history page.
Marking as "Answered" for now to raise visibility.
68 additional answers
    2021-08-13T17:14:59+00:00
    Unless it's a widespread extreme case, Microsoft typically only issues updates on Patch Tuesday; typically the 2nd Tuesday of the month. Based on the fact that there are relatively few affected devices overall, the absolute soonest I would expect a fix is Sept 14th.
    Judging from the reports, it's pretty widespread. Our entire fleet is affected, we have people switching to Mac or surface with Ryzen to avoid this.
    3 months. It's ridiculous. Apple would have been crucified, and has been crucified, for less.
    2021-08-13T18:05:57+00:00
    My Surface Laptop 3 is i7, 16GB RAM, 256G model, which also has been affected by the June firmware update bug for two months. Today just received a firmware update through Windows Update - Surface - Firmware - 13.0.1763.6. I am in Insider Dev and hopefully it will fix the problem.
    2021-08-15T22:10:40+00:00
    On my Intel Surface Laptop 3, the issue has been resolved with the new firmware update which I installed yesterday. I have been having this issue for a few months and Microsoft even sent me a replacement laptop. So, hopefully, it's all over now.
    2021-08-15T22:27:13+00:00
    Our organization was provided a work-around by Microsoft support that seems to work for all the devices we have tested this on thus far.
    You go into Device Manager > Universal Serial Bus controllers.
    Then, depending on your device you may have 1 or more 'USB Root Hub (USB3.0)'
    Eg My surface Book 2 has 1, the Pro 7 has 2.
    On all of the 'USB Root Hub (USB3.0)'
    Right-click > Properties > Power Management > then UNTICK "Allow the computer to turn off this device to save power".
