Because this problem may be caused by a rendering vulnerability in the new canvas APIs, we can prevent Google Maps from using these problematic APIs by setting the browser's User-Agent to an older version of the mobile browser's. I have a temporary solution to the problem:
You can download this Chrome extension at "https://chromewebstore.google.com/detail/djflhoibgkdhkhhcedjiklpkjnoahfmg" and set the User-Agent of Google Maps to Windows Phone 8. For Firefox, there are similar extensions available.
因为这个问题也许是由于canvas的新API的渲染漏洞引起的,我们可以通过设置浏览器的User-Agent为老版本的移动端浏览器来避免Google Maps使用这些有问题的API。我有一个临时缓解该问题的方法:
可以在“https://chromewebstore.google.com/detail/djflhoibgkdhkhhcedjiklpkjnoahfmg”下载这个Chrome拓展,将Google Maps的User-Agent设置为Windows Phone 8即可。对于Firefox,也有类似的拓展可以使用。
