Surface Pro X, Issues with Google Maps
2023-07-15T20:54:04+00:00
I am using:
Device name *******
Processor Microsoft SQ1 @ 3.0 GHz 3.00 GHz
Installed RAM 8.00 GB (7.54 GB usable)
System type 64-bit operating system, ARM-based processor
Pen and touch Pen and touch support with 10 touch points
Recently, after an update, when using Google maps, the names of the locations disappear.
Initially the maps shows all the detail
But few seconds later when everything is loaded, the town names disappear:
I thought this was a Chrome issue, thus cleared the cache etc. but this not fixed the issue.
I then tried different browsers MS Edge and Firefox. They all have the same issue.
I contacted Google and provided the above info, but they believe this is o/s issue and suggested I contact MS.
Is anyone able suggest how I can fixed this problem?
EDIT: Removed personally identifiable information (PII) from post.
    2024-02-17T14:47:30+00:00
    Because this problem may be caused by a rendering vulnerability in the new canvas APIs, we can prevent Google Maps from using these problematic APIs by setting the browser's User-Agent to an older version of the mobile browser's. I have a temporary solution to the problem:
    You can download this Chrome extension at "https://chromewebstore.google.com/detail/djflhoibgkdhkhhcedjiklpkjnoahfmg" and set the User-Agent of Google Maps to Windows Phone 8. For Firefox, there are similar extensions available.
    因为这个问题也许是由于canvas的新API的渲染漏洞引起的,我们可以通过设置浏览器的User-Agent为老版本的移动端浏览器来避免Google Maps使用这些有问题的API。我有一个临时缓解该问题的方法:
    可以在“https://chromewebstore.google.com/detail/djflhoibgkdhkhhcedjiklpkjnoahfmg”下载这个Chrome拓展,将Google Maps的User-Agent设置为Windows Phone 8即可。对于Firefox,也有类似的拓展可以使用。
    2024-05-01T05:18:05+00:00
    Thanks a lot, it works! It's the only solution I found on the internet after useless advice from Microsoft, Mozilla and Google...
    It definitely comes from a Windows Update a few days ago.
    I found a user-agent switcher on Firefox Plugins store which did the job.
