Repeated BSOD after firmware update - Surface pro 3, Windows 10
2015-09-30T05:24:22+00:00
Hey everyone
There was a firmware update for the SP3 I just did and my device now seems completely bricked. When I boot it, I instantaneously get a BSOD with one of those two messages : kernel security check failure or driver unloaded without cancelling pending operations.
The BSOD tells me I have to use a win10 device to boot it from, but when I tell the BIOS to boot with my USB win10 key, it doesn't and keeps telling that the OS can't boot and to use a win10 disc (no CD reader on the SP3). Nothing I've tried works so far.
I've had my sp3 for just over a year and I really liked it before windows 10, and I really hope I can get it fixed.
Thanks for your help,
Émile
2015-10-01T02:21:41+00:00
MODERATOR EDIT (10/5/2015): Steps listed here previously are now updated to the following.  If you receive a blue screen error after installing the 9/29/2015 Surface Firmware Update please start at step 1 to address.
Step 1 – System Restore Point
1.    Boot Surface using USB recovery media.  If you do not have recovery media you can download from here: http://www.microsoft.com/surface/en-us/support/warranty-service-and-recovery/downloadablerecoveryimage.  Once you have recovery media proceed to next steps.  Note:  The USB drive must be formatted to FAT32 (not NTFS) in order to work correctly.
2.    Press and hold the volume-down button while you press and release the power button.  When the Surface logo appears release the volume-down button.
3.    When prompted select the language and keyboard layout you want.
4.    Select Troubleshoot, then Advanced Options, followed by selecting System Restore then select the target operating system.
5.    In System Restore, click Next.
6.    Click on a system restore point that was prior to applying the System Firmware update. Please use a restore point 9/28 or earlier.
7.    Click Next.
8.    Click Finish.
9.    Click Yes when asked if you want to continue.
10.    After moving to an earlier restore point you should boot into Windows.
If you were able to restore to an earlier restore point you should now be able to use your Surface again, no additional steps are needed.  If you were not able restore to an earlier restore point or you did not have a restore point then continue to step 2 below.
Step 2 – Safe Mode
1.    Boot Surface using USB recovery media by pressing and holding the volume-down button while you press and release the power button.  When the Surface logo appears release the volume-down button.
2.    When prompted select the language and keyboard layout you want.
3.    Select Troubleshoot, then Advanced Options, followed by selecting Command Prompt.
4.    Type the following command in the command prompt and then press enter:
               bcdedit /set {bootmgr} displaybootmenu yes
5.    Type the following command in the command prompt and then press enter.
               exit
6.    Press Turn off your PC.
7.    Press the power button on Surface to turn it on.
8.    Press F8 when the Windows Boot Manager screen comes up to go to Startup Settings.
9.    Press “4” to enable Safe Mode.
10.    Surface may do disk checking as well as perform a scan and repair.  Surface will then restart.  If Surface does not do this and instead boots into Safe Mode, go to step 13.
11.    Press F8 when the Windows Boot Manager screen comes up to go to Startup Settings.
12.    Press “4” to enable Safe Mode.
13.    Surface will start in Safe Mode.  Sign into Surface.  Press the Windows Start Menu, press Power and select Restart.
14.    Press Enter when the Windows Boot Manager screen comes up to boot into Windows 10.
15.    Surface will start normally.  Sign into Surface.  Right-click the Windows Start Menu and click Command Prompt (Admin).
16.    Click Yes to allow this app to make changes.
17.    Type the following command in the command prompt and then press enter.
               bcdedit /set {bootmgr} displaybootmenu no
18.    Press the Windows Start Menu, press Power and select Restart.
If you are now able to boot into Windows you should now be able to use your Surface again, no additional steps are needed. If you were not able to boot into Windows then continue to step 3 below.
Step 3 – Reset Surface to factory settings
1.    Follow the steps in the article below to boot Surface using USB recovery media and reset Surface back to factory settings: http://www.microsoft.com/surface/en-us/support/warranty-service-and-recovery/usbrecovery
Please let us know how it goes.
Josh
187 additional answers
    2015-09-30T07:09:37+00:00
    I absolutely love the form factor and performance of my i7/512gb SP3, but utterly hate Windows (any version), including 10.
    I was suckered into moving from a Macbook air 11" believing that Windows 10 would be different.
    Bug ridden garbage, still with a tablet and desktop interface that is STILL confusing - worse than W8.
    For Sale sign going up and back to OSX for me. Sorry guys, Microsoft OS is done, in a few years even business will be using mobile OS's, no one wants to worry about drivers anymore.
    2015-09-30T07:14:50+00:00
    I have this exact same issue.  My WiFi died while I was using the device, so I restarted it through the start menu.  When it came back up from the restart, it said that it was installing firmware.  Once that finished, it restarted itself again, and now it refuses to boot with one of several bluescreen messages, but always the stop code 0xc0000001:
    DRIVER_UNLOADED_WITHOUT_CANCELING_PENDING_OPERATIONS (SurfaceIntegrationDriver.sys)
    ATTEMPTED_WRITE_TO_READONLY_MEMORY(SurfaceIntegrationDriver.sys)
    ATTEMPTED_WRITE_TO_READONLY_MEMORY(rdpbus.sys)
    2015-09-30T09:03:30+00:00
    Well, I have my SP3 up again, but it wasn't easy and I'm not feeling very secure.  I tried using the downloaded recovery image to do System Restore, which failed.  Startup Repair failed.  I tried using Refresh, and that failed, too.  I think I tried every option -- multiple times -- other than Reset (I didn't want to lose my files, which I hadn't backed up in a little over a week).
    What finally worked for me was getting to the Command Prompt to enable the legacy Advanced Boot Options to allow me to start in Safe Mode by hitting F8 when restarting.  My SP3 was then able to start, although it didn't seem to restart in Safe Mode, so that's confusing to me.  It did some system disk check and repair, IIRC, and then started normally.  Whew.  I've rebooted several times and all seems well, and the Firmware Update shows as successfully installed.
    I'd sure like to understand what the heck happened -- if anyone can shed any light, I'd appreciate it.  In searching, I came across a fair number of people who had the same issue with this particular firmware update, so I guess I'm relieved to know it wasn't just me.
    2015-09-30T09:42:21+00:00
    Thank you SO MUCH No IDLady.  Those steps fixed my machine as well (I actually didn't do anything once I booted into safe mode, just a simple restart).  I was terrified of losing everything on this machine, so thanks again for rescuing me!
