Repeated BSOD after firmware update - Surface pro 3, Windows 10
2015-09-30T05:24:22+00:00
Hey everyone
There was a firmware update for the SP3 I just did and my device now seems completely bricked. When I boot it, I instantaneously get a BSOD with one of those two messages : kernel security check failure or driver unloaded without cancelling pending operations.
The BSOD tells me I have to use a win10 device to boot it from, but when I tell the BIOS to boot with my USB win10 key, it doesn't and keeps telling that the OS can't boot and to use a win10 disc (no CD reader on the SP3). Nothing I've tried works so far.
I've had my sp3 for just over a year and I really liked it before windows 10, and I really hope I can get it fixed.
Thanks for your help,
Émile
2015-10-01T02:21:41+00:00
MODERATOR EDIT (10/5/2015): Steps listed here previously are now updated to the following.  If you receive a blue screen error after installing the 9/29/2015 Surface Firmware Update please start at step 1 to address.
Step 1 – System Restore Point
1.    Boot Surface using USB recovery media.  If you do not have recovery media you can download from here: http://www.microsoft.com/surface/en-us/support/warranty-service-and-recovery/downloadablerecoveryimage.  Once you have recovery media proceed to next steps.  Note:  The USB drive must be formatted to FAT32 (not NTFS) in order to work correctly.
2.    Press and hold the volume-down button while you press and release the power button.  When the Surface logo appears release the volume-down button.
3.    When prompted select the language and keyboard layout you want.
4.    Select Troubleshoot, then Advanced Options, followed by selecting System Restore then select the target operating system.
5.    In System Restore, click Next.
6.    Click on a system restore point that was prior to applying the System Firmware update. Please use a restore point 9/28 or earlier.
7.    Click Next.
8.    Click Finish.
9.    Click Yes when asked if you want to continue.
10.    After moving to an earlier restore point you should boot into Windows.
If you were able to restore to an earlier restore point you should now be able to use your Surface again, no additional steps are needed.  If you were not able restore to an earlier restore point or you did not have a restore point then continue to step 2 below.
Step 2 – Safe Mode
1.    Boot Surface using USB recovery media by pressing and holding the volume-down button while you press and release the power button.  When the Surface logo appears release the volume-down button.
2.    When prompted select the language and keyboard layout you want.
3.    Select Troubleshoot, then Advanced Options, followed by selecting Command Prompt.
4.    Type the following command in the command prompt and then press enter:
               bcdedit /set {bootmgr} displaybootmenu yes
5.    Type the following command in the command prompt and then press enter.
               exit
6.    Press Turn off your PC.
7.    Press the power button on Surface to turn it on.
8.    Press F8 when the Windows Boot Manager screen comes up to go to Startup Settings.
9.    Press “4” to enable Safe Mode.
10.    Surface may do disk checking as well as perform a scan and repair.  Surface will then restart.  If Surface does not do this and instead boots into Safe Mode, go to step 13.
11.    Press F8 when the Windows Boot Manager screen comes up to go to Startup Settings.
12.    Press “4” to enable Safe Mode.
13.    Surface will start in Safe Mode.  Sign into Surface.  Press the Windows Start Menu, press Power and select Restart.
14.    Press Enter when the Windows Boot Manager screen comes up to boot into Windows 10.
15.    Surface will start normally.  Sign into Surface.  Right-click the Windows Start Menu and click Command Prompt (Admin).
16.    Click Yes to allow this app to make changes.
17.    Type the following command in the command prompt and then press enter.
               bcdedit /set {bootmgr} displaybootmenu no
18.    Press the Windows Start Menu, press Power and select Restart.
If you are now able to boot into Windows you should now be able to use your Surface again, no additional steps are needed. If you were not able to boot into Windows then continue to step 3 below.
Step 3 – Reset Surface to factory settings
1.    Follow the steps in the article below to boot Surface using USB recovery media and reset Surface back to factory settings: http://www.microsoft.com/surface/en-us/support/warranty-service-and-recovery/usbrecovery
Please let us know how it goes.
Josh
187 additional answers
    2015-10-01T17:23:44+00:00
    I really don't want to spend a day or more trying to fix a bungled update; to top it off, my machine is a couple of weeks out of warranty, so the replies in the thread about "happily it's under warranty and they're sending me a new one" are more irritating than anything...if their update bricks my machine, is it going to be "sorry, out of warranty..."?
    I'm with you on this, and i asked about this earlier today..
    This should serve as a perfect example of why NOT to limit user choices.  In the Win7 that I'm typing this from, I can disable whatever updates I want, simply and quickly, yet the best I can try here is delaying driver updates and "MAYBE" it will prevent the issue.  Mabye.  That's wonderful.
    You are preaching to the choir.
    Considering the number of posts within the last day on this issue, shouldn't MS have immediately pulled this update?  I really don't have days to waste trying to get something working that was working fine, and that I didn't break, the forced update did.
    I asked them to pull the update when I first saw the trending here. I can only ASK. They have undisclosed criteria for making decisions like this. I don't work for Microsoft. Community Moderator's and MVP's are unpaid volunteers. I'm on YOUR side.
    Perhaps I'm being paranoid, as the update must have worked for some, but there's nothing worse than being on the road with your laptop and finding it won't boot no matter what you do, and you don't have backup machines with you to cover the time until you can get it working.
    I get this, I really do. I feel the same way. I was luckier than folks reporting problems here. No BSOD and successful install. I have other issues which MS says are specific to the router I use, so I rolled back the driver (not the firmware) by force installing the older .193 driver.
    So my real questions are, 1) how long before I can safely boot up my SP3 and not have a significant risk of having it bricked the next time I restart it?, and 2) warranty or no warranty, if an update damages something to where it needs to be sent in, is this going to be something they expect ME to pay for?  If so, why?  It would have been done without me having any say so or control over it, since they've eliminated the method that could have been used, to simply disable the update.
    If I were in your position, I'd do a manualy system restore point immediately. Then,  I'd disable device driver updates (unplug your router so you don't have an Internet connection while you boot up to do this) and hope this works. I've asked about #2. I don't know if I will get an answer.
    2015-10-01T19:18:08+00:00
    I can boot from usb but not restore from a point it says i cannot etc. Called microsoft and they never heard of it . If i buy a car i can also go back now microsoft does not have a centre to go to....
    Where can I download fresh win 10 image with drivers ?
    Thanks ! Frustrated because i also loose office from the license of a relative which is now already given out...
    What a frustration
    2015-10-01T19:40:16+00:00
    Did your Surface Pro 3 originally come with 8.1 or 10? If 8.1, you will not be able to download a 10 recovery image.
    2015-10-01T19:48:23+00:00
    Its blocking some, like me, from using any advanced actions. No Safe mode options even showed. Mine would boot from a official Microsoft Windows 10 USB but would not allow any restore, repair, etc options. Would try and say "failed". Will try the other option below when I have the time but will have to keep the system on till a solution is officially found.
