Repeated BSOD after firmware update - Surface pro 3, Windows 10
2015-09-30T05:24:22+00:00
Hey everyone
There was a firmware update for the SP3 I just did and my device now seems completely bricked. When I boot it, I instantaneously get a BSOD with one of those two messages : kernel security check failure or driver unloaded without cancelling pending operations.
The BSOD tells me I have to use a win10 device to boot it from, but when I tell the BIOS to boot with my USB win10 key, it doesn't and keeps telling that the OS can't boot and to use a win10 disc (no CD reader on the SP3). Nothing I've tried works so far.
I've had my sp3 for just over a year and I really liked it before windows 10, and I really hope I can get it fixed.
Thanks for your help,
Émile
2015-10-01T02:21:41+00:00
MODERATOR EDIT (10/5/2015): Steps listed here previously are now updated to the following.  If you receive a blue screen error after installing the 9/29/2015 Surface Firmware Update please start at step 1 to address.
Step 1 – System Restore Point
1.    Boot Surface using USB recovery media.  If you do not have recovery media you can download from here: http://www.microsoft.com/surface/en-us/support/warranty-service-and-recovery/downloadablerecoveryimage.  Once you have recovery media proceed to next steps.  Note:  The USB drive must be formatted to FAT32 (not NTFS) in order to work correctly.
2.    Press and hold the volume-down button while you press and release the power button.  When the Surface logo appears release the volume-down button.
3.    When prompted select the language and keyboard layout you want.
4.    Select Troubleshoot, then Advanced Options, followed by selecting System Restore then select the target operating system.
5.    In System Restore, click Next.
6.    Click on a system restore point that was prior to applying the System Firmware update. Please use a restore point 9/28 or earlier.
7.    Click Next.
8.    Click Finish.
9.    Click Yes when asked if you want to continue.
10.    After moving to an earlier restore point you should boot into Windows.
If you were able to restore to an earlier restore point you should now be able to use your Surface again, no additional steps are needed.  If you were not able restore to an earlier restore point or you did not have a restore point then continue to step 2 below.
Step 2 – Safe Mode
1.    Boot Surface using USB recovery media by pressing and holding the volume-down button while you press and release the power button.  When the Surface logo appears release the volume-down button.
2.    When prompted select the language and keyboard layout you want.
3.    Select Troubleshoot, then Advanced Options, followed by selecting Command Prompt.
4.    Type the following command in the command prompt and then press enter:
               bcdedit /set {bootmgr} displaybootmenu yes
5.    Type the following command in the command prompt and then press enter.
               exit
6.    Press Turn off your PC.
7.    Press the power button on Surface to turn it on.
8.    Press F8 when the Windows Boot Manager screen comes up to go to Startup Settings.
9.    Press “4” to enable Safe Mode.
10.    Surface may do disk checking as well as perform a scan and repair.  Surface will then restart.  If Surface does not do this and instead boots into Safe Mode, go to step 13.
11.    Press F8 when the Windows Boot Manager screen comes up to go to Startup Settings.
12.    Press “4” to enable Safe Mode.
13.    Surface will start in Safe Mode.  Sign into Surface.  Press the Windows Start Menu, press Power and select Restart.
14.    Press Enter when the Windows Boot Manager screen comes up to boot into Windows 10.
15.    Surface will start normally.  Sign into Surface.  Right-click the Windows Start Menu and click Command Prompt (Admin).
16.    Click Yes to allow this app to make changes.
17.    Type the following command in the command prompt and then press enter.
               bcdedit /set {bootmgr} displaybootmenu no
18.    Press the Windows Start Menu, press Power and select Restart.
If you are now able to boot into Windows you should now be able to use your Surface again, no additional steps are needed. If you were not able to boot into Windows then continue to step 3 below.
Step 3 – Reset Surface to factory settings
1.    Follow the steps in the article below to boot Surface using USB recovery media and reset Surface back to factory settings: http://www.microsoft.com/surface/en-us/support/warranty-service-and-recovery/usbrecovery
Please let us know how it goes.
Josh
187 additional answers
    2015-10-01T15:59:46+00:00
    I had the same issue this morning, specifically the driver_unloaded error - it took me about 4 hours but I did resolve it!
    The first thing I tried was creating a bootable USB drive and repairing from that - a great set of instruction on that process can be found here:
    Create bootable USB
    However I didn't have any restore points to use in the repair... my bad and I've made sure they're turned on now!
    No worries, there are other options such as a refresh. However, I appear to have had another simultaneous issue! When I tried to refresh it told me I wasn't signed in as an admin and I had no admin accounts on the machine - this meant the refresh couldn't proceed :-(
    What DID work was booting into safe mode. I then uninstalled the last couple of updates (to be safe) and everything is working fine now :-)
    I had to enable safe mode - a process which this link should help with:
    Enable safe mode
    But that seems to be the way forward.
    I hope this helps others too.
    Cheers
    Rich
    2015-10-01T16:16:58+00:00
    did you then turn off device driver updates?
    2015-10-01T16:47:33+00:00
    I stopped updates being automatic, so it will prompt me before installing any more.
    2015-10-01T17:00:13+00:00
    What a nightmare!  My SP3 hasn't been used in a week, so I was about to fire it up in preparation for a trip (so it could update etc. before I leave).  Fortunately I happened across this thread in pure coincidence...cleaning up some desktop links.
    Now I'm afraid to fire this thing up, in fear it's going to d/l the update and brick itself with me not being able to stop it (guess I can disconnect from wifi, but what good does that do me for actually being able to use it?
    I really don't want to spend a day or more trying to fix a bungled update; to top it off, my machine is a couple of weeks out of warranty, so the replies in the thread about "happily it's under warranty and they're sending me a new one" are more irritating than anything...if their update bricks my machine, is it going to be "sorry, out of warranty..."?
    This should serve as a perfect example of why NOT to limit user choices.  In the Win7 that I'm typing this from, I can disable whatever updates I want, simply and quickly, yet the best I can try here is delaying driver updates and "MAYBE" it will prevent the issue.  Mabye.  That's wonderful.
    Considering the number of posts within the last day on this issue, shouldn't MS have immediately pulled this update?  I really don't have days to waste trying to get something working that was working fine, and that I didn't break, the forced update did.
    Perhaps I'm being paranoid, as the update must have worked for some, but there's nothing worse than being on the road with your laptop and finding it won't boot no matter what you do, and you don't have backup machines with you to cover the time until you can get it working.
    So my real questions are, 1) how long before I can safely boot up my SP3 and not have a significant risk of having it bricked the next time I restart it?, and 2) warranty or no warranty, if an update damages something to where it needs to be sent in, is this going to be something they expect ME to pay for?  If so, why?  It would have been done without me having any say so or control over it, since they've eliminated the method that could have been used, to simply disable the update.
    Or do I need to lug along my faithful-but-large Toshiba Win7 16" laptop that I fortunately kept and is in great working order, with the Win10 update disabled?  We're leaving in a couple of days, and I'm not bringing along a machine that I'm afraid to boot up within range of an internet connection.  Please, MS, disable this update before it does more damage, and think again about restoring user control for those of us who are savvy enough to understand the situation and want to make our own decisions on our own equipment.
