Can't connect to WiFi Surface Pro 2.
2014-06-25T12:46:44+00:00
Iexperienced this problem this morning on my Surface Pro 2.  After being connected at a coffee shop, shutting down and rebooting at work I tried to connect to the wireless connection at work and am also getting the "no connection available".  I get the same network icon and red X.
When I troubleshoot I get "The Marvell AVASTAR Wireless Composite Device adapter is experiencing driver- or hardware-related problems"
Any help greatly appreciated.
2014-08-06T16:55:36+00:00
Hi SimonNissenbaum,
Thank you for contacting the Microsoft Community! I'm sorry to hear you are having connectivity issues with your Surface Pro 2. We appreciate you providing the steps that you have taken so far. We will be glad to help you find a viable solution.
First, we kindly ask you to double check that all and latest Windows updates are installed. Below you can find instructions on how to check for updates:
Also, please make sure you have followed the instructions presented by Zack_T  above, and the troubleshooting steps presented in the support article below:
Additionally, please try uninstalling and reinstalling the wireless driver:
  1. Go to the Desktop
  2. Swipe from the right
  3. Touch Settings
  4. Touch Control Panel
  5. Touch Device Manager
  6. Open the Network Adapters
  7. Right click on the Marvell Avastar 350N Wireless Network Controller
  8. Touch Uninstall
  9. *****Do not check the box*****
  10. Click on OK
  11. Restart your Surface.
  12. Once your Surface restarts, the Marvell driver will be reinstalled.
If none of the steps above work, and the issue persists, you might want to consider a Refresh:
We hope these solutions prove useful!
Keep us posted, we are always here to help!
Cheers,
2015-01-14T04:09:39+00:00
Hi SimonNissenbaum,
  3. Touch Settings
  8. Touch Uninstall
  10. Click on OK
Cheers,
Uninstalling the driver worked!!! It reinstalled it after restart.
2014-06-24T21:33:36+00:00
I re booted and it started working again, so I did a Windows update and so far so good.
54 additional answers
    2014-04-15T22:18:27+00:00
    Greetings Tom,
    I'd suggest doing a Refreshand/or Reset on your Surface Pro 2, installing all Windows Updates and seeing if the Marvell adapter continues to act the same.
    2014-04-17T15:14:47+00:00
    Thanks for the reply, Steven. Unfortunately, doing a refresh or reset would be a huge inconvenience for me. For now, I'll probably live with rebooting from time-to-time. Hopefully, MSFT will find the issue and fix in a future build.
