Edit: So Furmark isn't a typo for future mark. With the same test as you I got a peak TDP of 25W. I have a peak GPU power of about 19W which drops very quickly to 14W. After 75s proper throttling takes over and this drops to 11W where it stays until the
computer starts slowing everything down until the GPU takes a minimum of 3W. For a graphical version of what I just said see the plot below.
I used 3dmark to check unthrottled power usage. I am using the RT version so I can't get it to run until the computer gets hot. I can just try restarting tests over and over again.
The CPU+GPU limit is just about 25W. I had sustained GPU power usage at 13W+/-2 before various tests ended. I had a peak GPU power of 14.5W9
