Hey Microsoft ! Wake up ! I think we all have the same problem !
Brightness control is missing
Power button is out of control
Please repair it really quick !
Again the same old issue. After the last windows update (version 1903 build 18362. 239) i cant adjust the screen brightness ( is set in 100% and it is draining the battery).
This is the second time an Windows actualization creates this issue.
Does anyone have a clue how to fix it this time?
Thank you
Paulo Souza
I also made a reset. I'll wait to see if the problem comes up again. If necessary, I will post here when changes occur.
I solved the issue by resetting surface through the Recovery section choosing to keep personal files. Without creating any usb recovery key.
The procedure took 25 mins, with several reboots, I didn't have to do anything.
After the login, everything back to normal. My diagnosis is that the windows update process to 1903, while updating drivers/firmware/etc. created the issue.
Hope it helps you.
2 days. everything perfect for now. but there haven't been updates. the problem came up right after I upgraded to 1903.
Let's see if it comes up again.
Nothing changes.
