After uninstall TeamViewer I was able to change the brightness again.
Installed TeamViewer 11 again, restarted, and the control is still in place.
Again the same old issue. After the last windows update (version 1903 build 18362. 239) i cant adjust the screen brightness ( is set in 100% and it is draining the battery).
This is the second time an Windows actualization creates this issue.
Does anyone have a clue how to fix it this time?
Thank you
Paulo Souza
Excellent advice. This worked for me as well. Thank you.
I had Teamviewer 11 installed for many years. It seems that me chosing the option to 'black out remote display' might have resulted in the brightness display control being hidden.
Thanks to @MatheusStefani' s comment, I uninstalled TeamViewer and the control immediately re-appeared, without even restarting the PC.
I also had this problem before. I solved the problem after updating the 19587 version. If you do not find this version update in Windows Update, please enter the Windows Preview Experience Program and select the module that is fast. Go back to Windows Update and update to build 19587. After restarting, the system will return to normal.
This worked for me!
