On Sun, 21 Sep 2014 16:09:32 +0000, flyinggorilla wrote:
>>my Surface Pro 1 does connect well with my Samsung Smart TV series 7. However, my new Samsung Pro 3 wont connect. It finds the TV and then tries to establish connection and asks to wait - maybe the TV should not popup a PIN code - but that never happens and the connection times out. Interestingly the Surface Pro 3 gets listed in the Samsung network device settings and is set to "allowed" for connection but the Surface Pro 3 still wont connect. Note i have deployed all latest updates on Samsung TV as well as Surface Pro 3.
>>I would appreciate to get this working again.
it sounds like it was working previously as you mention getting it working
"again". and it sounds like you are trying to use Miracast. (charms, devices,
project)
There was another thread this week with a similar issue and she fixed it by
deleting all wireless profiles on her computer and configuring them again. For
info on deleting profiles, see
I don't know if this will fix your issue, but it is worth trying.
Barb
