Surface Go - Zoom Meetings
2020-02-06T00:19:41+00:00
Hi everyone,
I recently bought a Surface Go for work purposes.
I am wanting to use Zoom Meetings however when I try start/ join a meeting the computer wants me to run it through an application. When I search for an application, nothing comes up.
I have tried downloading "Teams" to then link with my Zoom account, and run Zoom through this application.
I have managed to link the account, however when I try start/ join a meeting, the same request comes up, asking me to run Zoom through another application.
Does anyone have any experience with using Zoom on a Surface Go at all? Is it doable?
Talia
Surface | Surface Go | Install and update
2020-02-11T00:10:14+00:00
Hi Taliaburton,
Thank you for your response.
It seems that there is no Zoom app available in the Microsoft Store app and I don't think you can use Microsoft Teams as the app to run for Zoom meetings. You may consider using the Zoom web client which works with the new Microsoft Edge and doesn't require switching out of S mode or if you need more advanced features you may need to switch out of S mode for you to install and run the Zoom app on your Surface Go if necessary.
You can find out more about how Zoom integrates with Teams at Getting Started with the Microsoft Teams Integration.
For additional resources and alternatives, please view Stay connected while at home.
Kind Regards,
Marrion Y.
Barb Bowman 80,815 Reputation points MVP Volunteer Moderator
2020-04-04T10:35:03+00:00
Microsoft - how quickly can you arrange for the ZOOM Cloud Meetings app to be available from the Microsoft Store. Zoom is essential, but I also do not want to leave S Mode.
This is up to the app developer (Zoom), not Microsoft. Zoom has to create a
compatible app and get it certified by the Store.
55 additional answers
    2020-04-23T19:54:40+00:00
    ah, I have a surface pro and it is encountering the same issue- asks to download an app that does not exist- I have to chair a national meeting tomorrow morning and will have to use my iPhone to access zoom this is a disaster-- I think the surface Pro is great but this will certainly kill it....
    2020-04-23T20:06:48+00:00
    Did you try the Zoom web client? It has limitations, but it will run inside Edge, so long as you have the latest version.
    2020-04-23T20:13:46+00:00
    Yes, you cannot use the web client of zoom with microsoft's S platform either.
