Surface Go - Zoom Meetings
2020-02-06T00:19:41+00:00
Hi everyone,
I recently bought a Surface Go for work purposes.
I am wanting to use Zoom Meetings however when I try start/ join a meeting the computer wants me to run it through an application. When I search for an application, nothing comes up.
I have tried downloading "Teams" to then link with my Zoom account, and run Zoom through this application.
I have managed to link the account, however when I try start/ join a meeting, the same request comes up, asking me to run Zoom through another application.
Does anyone have any experience with using Zoom on a Surface Go at all? Is it doable?
Talia
Surface | Surface Go | Install and update
2020-02-11T00:10:14+00:00
Hi Taliaburton,
Thank you for your response.
It seems that there is no Zoom app available in the Microsoft Store app and I don't think you can use Microsoft Teams as the app to run for Zoom meetings. You may consider using the Zoom web client which works with the new Microsoft Edge and doesn't require switching out of S mode or if you need more advanced features you may need to switch out of S mode for you to install and run the Zoom app on your Surface Go if necessary.
You can find out more about how Zoom integrates with Teams at Getting Started with the Microsoft Teams Integration.
For additional resources and alternatives, please view Stay connected while at home.
Kind Regards,
Marrion Y.
Barb Bowman 80,815 Reputation points MVP Volunteer Moderator
2020-04-04T10:35:03+00:00
Microsoft - how quickly can you arrange for the ZOOM Cloud Meetings app to be available from the Microsoft Store. Zoom is essential, but I also do not want to leave S Mode.
This is up to the app developer (Zoom), not Microsoft. Zoom has to create a
compatible app and get it certified by the Store.
55 additional answers
    2020-06-04T14:57:30+00:00
    That only works if your Surface is not in S(tupid) mode.
    2020-06-11T13:36:00+00:00
    U can use zoom via the browser itself
    2020-06-11T14:32:53+00:00
    HELP ....!!!! WHY OH WHY DID MICROSOFT PRODUCE THIS? I CAN'T DO ANYTHING!
    Thank you for helping out. I have tried that and it doesn't work but I will try it again.
    Can you tell me if the Surface RT is in S Mode?
    I am so disappointed with this tablet I was going to update it and get another but I'm not sure from the moment i purchased it I've not been able to do anything I've not been able to download apps etc which is crucial as I am a Primary school teacher: I don't know what to do with this thing.
    I am very disappointed in Microsoft's production of this tablet I paid £220! and I've had virtually no use out of it.
    To part with any more money to update would probably be foolish ... I just don't know :(
    Any further suggestions about how I can get zoom would be appreciated.
    Many thanks
