Unable to load "Switch Out of S Mode" screen in Microsoft Store
2019-07-29T23:01:55+00:00
I recently purchased a Microsoft Surface Go for travel, and although I'm enjoying it thus far there is a need to switch out of S Mode to install one or two additional programs. I've followed all of the steps to reach the "Switch Out of S Mode" screen in the Microsoft Store, however, the page never loads. Instead, it shows a blank store screen. Is there any other method to reach this area of the store?
Additionally, I've tried prior to updating Windows and after updating Windows with no luck.
Surface | Surface Go | Install and update
2019-07-31T21:06:03+00:00
8/1 Update:
Thank you for your feedback. We have completed our investigation and have published an updated version of the Microsoft Store app which includes a fix for this issue. To install this update:
From the taskbar, open Microsoft Store. Select More ...  > Downloads and updates > Get updates. Install available updates, including Microsoft Store version 11906.1001.24.0 (or later). For more help installing Microsoft Store updates, see Get updates for apps and games in Microsoft Store.
Greg
93 additional answers
    2020-09-07T14:52:21+00:00
    Same problem:
    I have tried restarting Windows update service, changed the product key (winpro) ran all updates successfully to date - however in the Microsoft Store I run the app to switch out of S mode and I run it - it asks for the PIN, then it says "working on it" forever. Nothing proceeds from there - and no error.
    STUCK. The only thing left is a clean install of Windows. This is beyond ridiculous.
    2020-09-08T23:49:51+00:00
    I am not provided the option to Switch out of S mode still. My Microsoft Store is up to date and I have Windows 10 Home in S Mode. I was communicating with a rep and was advised that I may NEED to upgrade to Windows 10 Pro in S mode first for $99 and then try... Is that true?
    2020-09-09T04:37:06+00:00
    When I was trying to get out of s mode last year, I tried upgrading to Windows 10 Pro in S Mode and it did not work. I was able to get a refund, but if I was you, I would not spend money on that. I was only able to get out of s mode by doing a factory reset and reinstalling Windows 10 onto my laptop through a flashdrive. I called Microsoft support 5 times and they could not even help me.
  4. Deleted
