Unable to load "Switch Out of S Mode" screen in Microsoft Store
2019-07-29T23:01:55+00:00
I recently purchased a Microsoft Surface Go for travel, and although I'm enjoying it thus far there is a need to switch out of S Mode to install one or two additional programs. I've followed all of the steps to reach the "Switch Out of S Mode" screen in the Microsoft Store, however, the page never loads. Instead, it shows a blank store screen. Is there any other method to reach this area of the store?
Additionally, I've tried prior to updating Windows and after updating Windows with no luck.
Surface | Surface Go | Install and update
2019-07-31T21:06:03+00:00
8/1 Update:
Thank you for your feedback. We have completed our investigation and have published an updated version of the Microsoft Store app which includes a fix for this issue. To install this update:
From the taskbar, open Microsoft Store. Select More ...  > Downloads and updates > Get updates. Install available updates, including Microsoft Store version 11906.1001.24.0 (or later). For more help installing Microsoft Store updates, see Get updates for apps and games in Microsoft Store.
Greg
93 additional answers
    2019-11-09T01:15:31+00:00
    I also have a new Lenovo laptop with S mode, and I have yet to find a way to exit S mode.  MS Support pages on the subject do not respond when contacted. One option which is not free is MS telephonic support - nothing I'll do lightly, but if I cannot get this laptop out of S mode, I'll return it and buy something without that feature. Another option is to pay $99 to upgrade to 10 Pro, which advertises the ability to load outside features, but 10 Home advertises the same thing., so not convinced this is a viable option.
    2019-11-22T14:38:10+00:00
    fix doesnt work on lenovo yoga 630
    what do i do
    2019-11-23T12:24:55+00:00
    it didnt work on a lenovo yoga 630. tried it 12 times including after rests. not even the geeks at best buy could fix it. machine is stuck
    2019-11-23T19:58:22+00:00
    I managed to figure out how to get out of s-mode. Not sure if it will work for you, but I downloaded an ISO file to a flash drive, and reinstalled/performed a clean installation of Windows 10. I can't find the exact tutorial I used to follow the steps, but I found a close one:
    https://www.pcmag.com/article/352209/how-to-run-windows-10-from-a-usb-drive
    You can find the installation media download tool here:
    https://www.microsoft.com/en-us/software-download/windows10
    It was a lot of work to figure out how to get out of s-mode, and the Windows support team over the phone barely helped. I can't believe Windows makes it this hard for people to switch out of s-mode, and they don't even know how to help their customers.
