How do I correct display scaling issues on Surface Pro 4
2016-02-19T16:31:28+00:00
I'm noticing display scaling issues and docking issues on the Surface Pro 4.  I'm using the docking connector and have two Dell 24" Ultrasharp U2415 monitors.  When I undock the Surface, the text is aliased very poorly on the Surface display, not crisp as it should be.  Certain elements appear fine, but my browser, Outlook 2016, and other apps have poor quality text.  A restart is required to get the text back to its normal hi-DPI quality.
Secondly, if I start a program while undocked and dock the surface, some apps are scaled up (both text and UI elements of the window) and others are fine.
Lastly, a few times when the SP4 is docked and I return from being away for a few minutes, my external displays don't kick on.  Clicking the mouse or pressing keys on the keyboard do nothing.  Occasionally, the SP4 display will activate and my mouse/keyboard will control work.  I've tried disconnecting the dock connector, power cycling the dock, but only restarting the SP4 will correct this issue.
In general a restart is required to resolve any of these issues.  Is this the result of buggy display drivers or something else?
I've installed the latest SP4 firmware update and have the latest OS updates through Windows Update, as of this morning, February 19, 2016.
2016-04-28T16:48:01+00:00
Hello SP4_user11,
A lot of work was done in Windows 10 to support high resolution screens, such as the Surface Pro 3, Surface Pro 4, Surface Book, and third-party laptops and tablets with screen resolutions above 1080p. However, there are issues that occur when using Office apps on these devices when connecting to an external monitor with a lower resolution.
To find out more about what has been improved and what is still being worked on, please check out these articles:
The current and future improvements are dependent on having Windows 10 Creators Update installed. So if you have not yet updated, please start with that.
Best Regards
52 additional answers
    2016-10-11T07:13:51+00:00
    The Surface Pro 3 have a maximum resolution of 3200x2000@60Hz video output. We suggest that you purchase a new cord that would display your desired resolution.
    Regards.
    How is your advice connected to reported Surface Pro 4 problems?
    External display resolutions doesn't matter, the issue mentioned in this thread depends only on scaling. I've tried with 4k monitors and standard 1920x1200 HD with the same results.
    2016-10-11T05:40:35+00:00
    Regards.
    2016-10-10T05:54:40+00:00
    Let’s get this resolved by updating your devices with the latest Windows and Firmware Update.
    Let us know the results.
    Regards.
    Hi there,
    No, there are no available updates. Everything is up to date.
    BTW This "copy/paste" style of replies wouldn't help anyone. If you want to help please read carefully reported issues and try on yourself prior to post such worthless "advice".
    2016-10-10T03:56:41+00:00
    Regards.
