Surface Earbuds - Not Charging and No LED Light
2021-12-29T04:41:42+00:00
I purchased a new pair of surface earbuds from Best Buy and out of the box no charge or LED light to indicate they even work. I charge with the USB-C charger in the box and nothing. Charged for an hour and unable to turn on to pair with my Surface Duo 2. I attempted to plug them into my Surface Pro 8.....Nothing! I immediately return to Best Buy and exchange for a new pair. Get home and the same exact thing. Zero charge. When plugged in via the USB-C no LED light - JUST DEAD! A new adopter of Surface products from Apple and I have to say I have never experienced this EVER! I am accustomed to at least a few hours of charge out of the box. At least enough to pair the device. Two different sets of earbuds purchased brand new out of the box with zero charge, will not turn on and completely unable to pair or reset because they are an absolutely DEAD paperweight. Any suggestions or assistance? Pairing earbuds should not be this difficult.
Surface | Surface Duo | USB-C
    2022-06-18T21:49:45+00:00
    my earbuds wont charge and they won't turn blue, and they are not charging, and my earbuds are not working, not charging or not turning blue and could come to call support for my earbuds
    2022-04-20T03:43:11+00:00
    I have the same issue, and following the procedure above does NOT help.
    2021-12-29T17:09:15+00:00
    Hello NewSurfaceAdopter,
    Thanks for reaching Microsoft Community. We're sorry to learn that your earbuds are not charging and not connecting. We'll do our best to help.
    When there's no LED light on the case and not connecting to the host device, it could be a problem with the firmware or possible hardware issue. We suggest to reset the firmware of your earbuds. Follow the methods below:
    Reset the Firmware
    On a Windows 10/11 PC
    1. Plug the USB cable into your PC or into a USB power adapter (not included) for a wall outlet.
    2. Press and hold the Pair button on the bottom of the charging case for less than 20 seconds.
      Note: Make sure you don't hold the Pair button down for longer than 20 seconds. If you do, it'll reset your Surface Earbuds to the default factory settings.
    3. While still holding down the Pair button, connect the USB-C end to your case.
    4. Release the Pair button.
    But if issue still persists, we suggest to contact our support via Contact Us Microsoft Support to seek options for your device and for further assistance. You can also contact them via phone, see Global Support Phone Numbers. For detailed instructions on how to contact our support, click here.
    Regards,
    StevenK
    2022-06-16T16:50:46+00:00
    Facing a similar issue. The buds pair to the Surface no problem. The issue is that the LED does not illuminate when the case is plugged in, although it does appear that the buds themselves are charging. It's annoying not to be able to rely on the LED.
    2022-01-26T07:44:38+00:00
    BTW, note for the support content team - it's really hard to follow the instructions that involve looking for the LED signals, when the problem is with the LED not displaying it all.
