Surface Pro 7 Overheating when charging
2019-12-12T20:59:39+00:00
So I've purchased and exchanged 3 brand new surface pro 7s in the last 20 days from best buy because of this issue. Everytime I plugged in the charger, within 5 mins, the backside of the Surface pro 7 starts overheating to an uncomfortable temperature. This was the case for the last 2 Surface Pro 7s as well. Their respective lot number was 1945 and 1943. I'm beginning to wonder if this is an issue with this particular batch ... Is there any answers for this?
    2021-12-01T02:41:33+00:00
    It gets hotter while plugged in due to the fast charging. This charging method generates a lot more heat than previous generation surface devices.
    It's also important to keep in mind the body is made of magnesium. It was made of this material to absorb the heat from the CPU. So the body acts as kind of a large heatsink. This is normal but shouldn't result in an unresponsive touch screen. More than likely the driver was updating. That would also explain the audible "disconnect" notification.
    I recommend ensuring the device is fully updated, then runs some personal tests on the device to see how it functions. I hope this helps.
  2. Deleted
