Battery Degradtion : Surface Pro (5 , 2017) (I5, 256 gb)
2019-06-15T07:08:49+00:00
I just wonder if some of you who own this version of Surface Pro have the same issues like mine as in below:
ISSUE: Battery at full charge drastically degraded and swingsConditions observed lately:-The battery runs out within 1-2 hrs just by browsing websites/Youtube (tested on both Chrome&M. Edge)
-To fully Charge, takes only around 20-30mins (Est. full charge not accurate)
-Battery sometimes drops by a ridiculous amount E.G. by 20-30% in 1 sec.After checked with Battert Report run in CMDAt Designed Cap at : 45,000,
My Full Charge history as below (Noted that i tried to reset the windows and all previous history is gone so this is what i remember)
First bought (Jan,2018)
Full Charge 2018                                 : around 40,000 0 44,000
Full Charge 2019(Early months)          : Starting to drop to 35,000
Full Chrage as of the last few months : 25,000
Full charge as the last few days of notice: Swings from 22,000 to 9,000 life cycles at 383
Now i cant use it outside without charger. This is very frustating while working**.**
As my device is out of warranty, after searching online, the onl way is replacement at 500USD which seems ridiculus to me just because of battery. I bought this expensive device for the reason of long-term use. this is just a year and a half. Shouldn't it last for 4-5 years for its price?
If you have the same issues and any solutions/suggestions, feel free to share and discuss.
**Update 1 8/19/19:**I can't turn on. I lost my files those i didn't back up. I don't have any other computer to use.
Update 2 8/22/19: I just bought a new PC just to work. I cant wait for 1-2 weeks (Send to another country as  there's no microsoft HQ in Thailand) and spend 500USD for just battery replacement.
I kinda gave up and thought it was my fault back then. Now, if you have the same problems. Please up vote.
Update 3 9/1/19:
Seems like my battery is completely dead after testing at a computer shop.
Conclusion:
I am not a hardcore user. In less than 400 cycles, battery (all 4 cells) is dead.
The battery life of my surface pro lasted less than 2 years.
That means you have to pay 500 USD every 2 years. (Could have used this money to upgrade lol)
Maybe 2 in 1 tablets/laptops are not ready for practical use.
Maybe other brands are geting better.
Why do we have to refurbish/replace the device for just a battery which shouldn't cost more than 50 USD.
P.S.
For those who cant even turn the device on,
It's either the circuit is broken duee to defect/unfunctional battary
OR
The battery is completely dead
Worst case = both.
    2019-08-22T03:04:49+00:00
    Just a follow-up on my last post...
    It seems that there have been 3 firmware updates for the Surface Pro 2017 (5th gen), which were supposedly aimed at battery stability/reliability issues. These were dated:
    August 2019
    September 2018
    March 2018
    I started noticing worsening battery issues roughly correlating with the Aug19 and Sep18 updates.
    2019-08-22T04:30:42+00:00
    Update 2:
    I just bought a new PC,Monitor and other devices since i need a computer to work. (1,700 USD)
    Anyway, does Microsoft actually care what's happenning ?
    Do they really check Feedback hub?
    And do people know it exists as i don't see people use and upvote threads.
    Do people who have the same problem realize this could be the the defect hardware?
    Of course most of them dont. They just buy a new one or get replacement $$$$.
    I cant wait to spend 500 usd (better buy a new one).
    Or wait to send to the nearest HQ (another country) which would take 1-2 weeks.
    I won't complain about my work and files. Because you know when you are working and suddenly your only computer is dead. Some files are not backed up on cloud.
    My battery drains faster than i can say disappointing.
    Just kidding. Actually i cant turn my surface pro on at all.
    2019-08-22T04:40:25+00:00
    Same. I just bought a brand new PC.
    I thought my surface could last 4 - 5 years.
    Next laptop will not be from Microsoft if they won't fix this.
  4. Barb Bowman 80,805 Reputation points MVP Volunteer Moderator
    2019-08-22T09:58:00+00:00
    >Lately, batteryreport appears to be reporting random numbers for the full-charge capacity
    I can see that. We can try removing and reinstalling the battery driver. To do
    this:
    1. Plug in your Surface.
    2. Select the search box in the taskbar, enter device manager, and in the search
    results, select Device Manager.
    1. Select the arrow next to the Batteries category.
    2. Double-tap or double-click Microsoft ACPI-Compliant Control Method Battery,
    select the Driver tab, and select Uninstall > OK. (Or you can right-click
    Microsoft ACPI-Compliant Control Method Battery and select Uninstall.)
    1. Leave your Surface plugged in.
    2. After you remove the battery driver, install Surface and Windows updates. Go
    to Settings, Updates, and check for updates manually and install any updates
    that are available.
    1. Restart your Surface and test to see if anything has changed.
    2019-08-22T13:16:47+00:00
    You described to a tee the failure sequence, including the shutting down on its' own.
    To that end I suggest you copy all of your files, as over this past weekend the final curtain fell.  Unit will no longer boot up; appears to have power so I suspect the SD drive just crapped out.
    Thanks for sharing the idea, Philip.
    I just can't believe it's an SSD problem. All the symptoms led to battery and then power management failure. When the device shut down on its own, it remained OFF for a few seconds before it came ON again, still on its own. As far as I can tell, the power was too weak and the device had to rest for some time to get enough power to survive. This may also explain why I saw "discharging" from the battery indicator at times. And now it seems there's no way for the device to have power to get up.
