Battery Degradtion : Surface Pro (5 , 2017) (I5, 256 gb)
2019-06-15T07:08:49+00:00
I just wonder if some of you who own this version of Surface Pro have the same issues like mine as in below:
ISSUE: Battery at full charge drastically degraded and swingsConditions observed lately:-The battery runs out within 1-2 hrs just by browsing websites/Youtube (tested on both Chrome&M. Edge)
-To fully Charge, takes only around 20-30mins (Est. full charge not accurate)
-Battery sometimes drops by a ridiculous amount E.G. by 20-30% in 1 sec.After checked with Battert Report run in CMDAt Designed Cap at : 45,000,
My Full Charge history as below (Noted that i tried to reset the windows and all previous history is gone so this is what i remember)
First bought (Jan,2018)
Full Charge 2018                                 : around 40,000 0 44,000
Full Charge 2019(Early months)          : Starting to drop to 35,000
Full Chrage as of the last few months : 25,000
Full charge as the last few days of notice: Swings from 22,000 to 9,000 life cycles at 383
Now i cant use it outside without charger. This is very frustating while working**.**
As my device is out of warranty, after searching online, the onl way is replacement at 500USD which seems ridiculus to me just because of battery. I bought this expensive device for the reason of long-term use. this is just a year and a half. Shouldn't it last for 4-5 years for its price?
If you have the same issues and any solutions/suggestions, feel free to share and discuss.
**Update 1 8/19/19:**I can't turn on. I lost my files those i didn't back up. I don't have any other computer to use.
Update 2 8/22/19: I just bought a new PC just to work. I cant wait for 1-2 weeks (Send to another country as  there's no microsoft HQ in Thailand) and spend 500USD for just battery replacement.
I kinda gave up and thought it was my fault back then. Now, if you have the same problems. Please up vote.
Update 3 9/1/19:
Seems like my battery is completely dead after testing at a computer shop.
Conclusion:
I am not a hardcore user. In less than 400 cycles, battery (all 4 cells) is dead.
The battery life of my surface pro lasted less than 2 years.
That means you have to pay 500 USD every 2 years. (Could have used this money to upgrade lol)
Maybe 2 in 1 tablets/laptops are not ready for practical use.
Maybe other brands are geting better.
Why do we have to refurbish/replace the device for just a battery which shouldn't cost more than 50 USD.
P.S.
For those who cant even turn the device on,
It's either the circuit is broken duee to defect/unfunctional battary
OR
The battery is completely dead
Worst case = both.
    2021-08-14T11:11:14+00:00
    I've been wondering if you used that surface to depleted, and charged back 100% like most of the ppl, it's no wonder it died within 400 cycles.
    I don't want to blame you, and doesn't want to retiocinate either. As far as i know li-ion, and pol batteries dont like to go below 20%, or higher than 80%. Charging them like this, could keep up about 1500 cycles.
    2021-08-14T11:22:47+00:00
    If what you say is true, then no one should keep their device plugged in.
    I'd really like to see how someone manages not to break that min/max limit.
    2021-09-01T12:10:58+00:00
    Hi All,
    Having the same issue with my Surface pro 5 core i7 - 16 GB of Ram - 512 SSD (bought in Sep 2017 more than 1800$ without the keyboard and the pen I had bought separately)... and Microsoft is playing deaf or dead.. (as you prefer)
    I would really enjoy US customers to start a class actions against them for this as most (all?) of this Surface Pro 5 buyers are affected by this issue. Not easy to do such a class action here in Europe also because there are less customers who bought this PC ...
    Never again Microsoft hardware/PC for sure ...
    2021-09-01T13:29:29+00:00
    So sorry you are having this issue too.
    And I agree, PLEASE USA customers, start a class action suit and we Europeans will join you. We deserve to be compensated!
    2021-10-18T12:46:30+00:00
    I have the same on my SP5 , so annoying, it started with it running out of battery very fast when not on power. Now I cannot take it off the power or it reboots itself.
    I really loved the Surface Pro and its a real shame that it only lasted a couple of years when spending £1500.
    I hope someone can do something about it,
