Battery Degradtion : Surface Pro (5 , 2017) (I5, 256 gb)
2019-06-15T07:08:49+00:00
I just wonder if some of you who own this version of Surface Pro have the same issues like mine as in below:
ISSUE: Battery at full charge drastically degraded and swingsConditions observed lately:-The battery runs out within 1-2 hrs just by browsing websites/Youtube (tested on both Chrome&M. Edge)
-To fully Charge, takes only around 20-30mins (Est. full charge not accurate)
-Battery sometimes drops by a ridiculous amount E.G. by 20-30% in 1 sec.After checked with Battert Report run in CMDAt Designed Cap at : 45,000,
My Full Charge history as below (Noted that i tried to reset the windows and all previous history is gone so this is what i remember)
First bought (Jan,2018)
Full Charge 2018                                 : around 40,000 0 44,000
Full Charge 2019(Early months)          : Starting to drop to 35,000
Full Chrage as of the last few months : 25,000
Full charge as the last few days of notice: Swings from 22,000 to 9,000 life cycles at 383
Now i cant use it outside without charger. This is very frustating while working**.**
As my device is out of warranty, after searching online, the onl way is replacement at 500USD which seems ridiculus to me just because of battery. I bought this expensive device for the reason of long-term use. this is just a year and a half. Shouldn't it last for 4-5 years for its price?
If you have the same issues and any solutions/suggestions, feel free to share and discuss.
**Update 1 8/19/19:**I can't turn on. I lost my files those i didn't back up. I don't have any other computer to use.
Update 2 8/22/19: I just bought a new PC just to work. I cant wait for 1-2 weeks (Send to another country as  there's no microsoft HQ in Thailand) and spend 500USD for just battery replacement.
I kinda gave up and thought it was my fault back then. Now, if you have the same problems. Please up vote.
Update 3 9/1/19:
Seems like my battery is completely dead after testing at a computer shop.
Conclusion:
I am not a hardcore user. In less than 400 cycles, battery (all 4 cells) is dead.
The battery life of my surface pro lasted less than 2 years.
That means you have to pay 500 USD every 2 years. (Could have used this money to upgrade lol)
Maybe 2 in 1 tablets/laptops are not ready for practical use.
Maybe other brands are geting better.
Why do we have to refurbish/replace the device for just a battery which shouldn't cost more than 50 USD.
P.S.
For those who cant even turn the device on,
It's either the circuit is broken duee to defect/unfunctional battary
OR
The battery is completely dead
Worst case = both.
    2020-12-16T04:51:38+00:00
    Same situation here with Surface Pro 5. Battery charge lasts only 1.5 hours. Tried all the options mentioned online. I do not feel like doing standard exchange for $500, it seems not worth. I'm planning to switching to Apple New Mac book Pro M1.
    Thanks MS!
    2020-12-27T07:40:20+00:00
    DESIGN CAPACITY 45,000 mWh
    FULL CHARGE CAPACITY 13,180 mWh
    CYCLE COUNT 437
    Have the same problem. I bought my comp back in Sept 2017 and so disappointed with this purchase. Didn't even last a long time. Now I always have to keep my computer plugged in cause it would randomly die even if it says I still have over 50% battery left. Also, my perfectly fine charger stopped working on this computer so I had to use my old surface pro 3 charger to charge my 5th gen.
    I also talked to Microsoft agent about it and they told me I could get it fixed (which costs about $600)
    but I ain't gonna spend more money on something that cant even last 5yrs.
    2020-12-27T08:34:34+00:00
    CYCLE COUNT 437
    Shawn,
    its wiser to get a new set . My next nitemare is the touch screen malfunction! To replace a battery and a touch screen? no way.
    Cheers!
    2020-12-27T08:42:11+00:00
    And they just continue to pretend to be deaf. It was three or four years ago that I first wrote on this post and have been receiving messages from many others with the same problem ever since. Yet, when I finally found a way to contact a real Microsoft person by telephone (nearly impossible!), they had the gall to tell me that they had never heard of this problem, that no one else had ever reported it. I know it wasn't that person's fault, they were following orders for the response to this question. I will never buy another Microsoft hardware product again. I wish I could do away with Windows and Office too, but it is currently not possible. I will as soon as it is. I wish someone on this post would look into initiating a class action suit against them; I can't because I live outside of the USA. Someone, please do it!
    2020-12-27T11:27:00+00:00
    I'm late on this, because I needed some time to investigate this issue on my children's Surface 5 from 2017. I have exactly the same problem and so the Surface is useless after 2.5 yrs (issues since summer). Is there any chance to get some warranty or help from MS or is the only way not to buy MS products in the future any more?
