Battery Degradtion : Surface Pro (5 , 2017) (I5, 256 gb)
2019-06-15T07:08:49+00:00
I just wonder if some of you who own this version of Surface Pro have the same issues like mine as in below:
ISSUE: Battery at full charge drastically degraded and swingsConditions observed lately:-The battery runs out within 1-2 hrs just by browsing websites/Youtube (tested on both Chrome&M. Edge)
-To fully Charge, takes only around 20-30mins (Est. full charge not accurate)
-Battery sometimes drops by a ridiculous amount E.G. by 20-30% in 1 sec.After checked with Battert Report run in CMDAt Designed Cap at : 45,000,
My Full Charge history as below (Noted that i tried to reset the windows and all previous history is gone so this is what i remember)
First bought (Jan,2018)
Full Charge 2018                                 : around 40,000 0 44,000
Full Charge 2019(Early months)          : Starting to drop to 35,000
Full Chrage as of the last few months : 25,000
Full charge as the last few days of notice: Swings from 22,000 to 9,000 life cycles at 383
Now i cant use it outside without charger. This is very frustating while working**.**
As my device is out of warranty, after searching online, the onl way is replacement at 500USD which seems ridiculus to me just because of battery. I bought this expensive device for the reason of long-term use. this is just a year and a half. Shouldn't it last for 4-5 years for its price?
If you have the same issues and any solutions/suggestions, feel free to share and discuss.
**Update 1 8/19/19:**I can't turn on. I lost my files those i didn't back up. I don't have any other computer to use.
Update 2 8/22/19: I just bought a new PC just to work. I cant wait for 1-2 weeks (Send to another country as  there's no microsoft HQ in Thailand) and spend 500USD for just battery replacement.
I kinda gave up and thought it was my fault back then. Now, if you have the same problems. Please up vote.
Update 3 9/1/19:
Seems like my battery is completely dead after testing at a computer shop.
Conclusion:
I am not a hardcore user. In less than 400 cycles, battery (all 4 cells) is dead.
The battery life of my surface pro lasted less than 2 years.
That means you have to pay 500 USD every 2 years. (Could have used this money to upgrade lol)
Maybe 2 in 1 tablets/laptops are not ready for practical use.
Maybe other brands are geting better.
Why do we have to refurbish/replace the device for just a battery which shouldn't cost more than 50 USD.
P.S.
For those who cant even turn the device on,
It's either the circuit is broken duee to defect/unfunctional battary
OR
The battery is completely dead
Worst case = both.
    2019-08-23T03:24:58+00:00
    I have a surface pro 5 that I actively keep up to date with windows update. Recently experienced increasingly shorter battery life, with very slow performance, then a few bouts of shutdown upon removal of power supply even though the battery indicates full charge, and then it no longer boots.... Anyone has this issue?
    My machine died even though powercfg /batteryreport recently started showing 101%, up from the previous 30%/50%. What do your reports show?
    If you are experiencing diminishing performance and battery life, please consider doing backups actively.  I now have a dead Surface on hand that does not boot.
    Crossposted from  https://mspoweruser.com/battery-issues-strike-surface-users-once-again-with-new-surface-pro-5-and-6-tablets-affected/
    2019-08-23T03:26:36+00:00
    BTW, I cannot provide the battery report since it is inside a dead surface now.  It is less than 2 years old ><
    2019-08-23T03:36:38+00:00
    saw it. Cant click upvote. Don't know why.
    2019-08-23T14:44:23+00:00
    Sorry to hear your SP5 is dead.
    I am sure you have tried the following, but curiously if your SP5 responded to any of them at all?
    https://support.microsoft.com/en-us/help/4023537/surface-wont-turn-on-or-wake-from-sleep
    2019-08-24T06:23:30+00:00
    Yes, probably getting it fixed today by a computer shop.  Goodbye microsoft.
