Under the load that you described it would seem totally normal for the fan to whirl.
Surface Pro 3 - Excessively loud fan, constant overheating during idle and light tasks (now on my second, third, fourth Surface Pro 3 i7)
Yea, there's definitely a problem. I'm on my second third fourth Surface Pro 3 after replacing what I suspected to be a defective unit and this one is exhibiting the same issues as the one returned. Not very happy at
the moment as you can guess. I'm assuming that, with a working unit, you're not supposed to even hear the fan under normal usage.
Right out of the box, before & after all updates and firmware are installed: the back of the unit becomes uncomfortably hot and its fan spins very loudly on idle and while performing minor tasks such as web browsing (even sites without flash or heavy ad use).
I was surprised to hear it the first time, as it sounds like white noise coming from the right speaker. Even under its idle state, my Surface Pro 3 is currently the loudest thing in my office (and that's including my PC running 3 video cards SLI). At its peak (IE: high octane tasks like browsing slashdot.com and reading OneNote entries), the fan noise is ear-piercing and the heat produced is immensely hot. I mean, it's not something you'd want to hold, immense.
Here are some other notes:
- Surface Pro 3 i7 512MB
- My Order/replacement sources:
- SP3 #1: Pre-ordered on MicrosoftStore.com- Lot No/Date: 1429
- SP3 #2: Replacement from the Boca Raton Microsoft Store on 8/2 - Lot No/Date: 1428
- SP3 #3: Replacement from the Aventura Mall Microsoft Store on 8/4 - Lot No/Date: 1429
- SP3 #4: Advance replacement directly from Surface support on 8/7 - Lot No/Date: 1430 ( See 8/16 update below )
- Occurrence examples:
- Instantly after resuming from stand-by via pen double-tap.
- Browsing "light-weight" sites like answers.microsoft.com
- Watching a Youtube video.
- Shutting down & rebooting the machine.
- The highest I've seen the CPU was around 34%, mainly due to One Drive Sync process.
- Screen brightness set to about 30%
- My office room temperature is about 73º F
- Doesn't matter if keyboard is attached or not. No case used.
- Doesn't matter if plugged in (surge protector or not).
- CPU and graphic temperatures after 5 minutes
- Fan whilst idle (video)
After dropping over $2k on a product, this isn't what I expect to see after 3 minutes of light web browsing:
8/20 - Temp warnings continue...
Got the temperature warning for the first time with my fourth unit. This time while applying the 8/19/2014 firmware update. A reboot during a firmware flash doesn't seem like a safe thing for a device to do. :(
8/16 - Yeah...
Just powered up Sudoku. Played it for a bit and left it running
- After about 2 mins, the fan is at a volume of what I'd describe low and it's warm but not uncomfortably so.
- After about 5 mins, the fan is definitely louder and while it's considerably less noisier than my first unit (which to me, was like a very high-pitch whistle), it's hot to the point where I wouldn't want to hold on to it for very long.
This unit has not given me the temperature warning as yet, but I have to admit that it's still quite discouraging to hear the fan kick in with game as light as Sudoku. Especially since my previous Surface Pro 2 and Yoga laptop, which this SP3 should be replacing, runs much cooler and quieter.
I really want this thing to work like a tablet when doing tablet tasks, and if the fan kicks in once and awhile for doing heavy laptop tasks like 3D gaming or video encoding then I wouldn't mind much. But I've gone through four Surface Pro 3's and it leaves me to wonder why they get as hot as they do when doing something unsubstantial like web surfing while an iPad can run much heavier duty 3D gaming and not feel like you're baking chocolate chip lava cookies on metal sheet you're holding with your bare hands.
I'm waiting on MS's public response to these issues, but honestly I can't help but feel a bit duped. Don't get me wrong, I'm in love with the aesthetics, speed and weight of the SP3, but what happened to the device Panos Panay was talking about (video)? What happened to not even noticing there's a fan? Why do people have to resort to using alternative cooling methods to get laptop performance out of a device marketed to replace them (video)?
I hope something can be done. And I hope that that something isn't waiting for the Surface Pro 4.
8/9 - Fourth one's the charm? Cautiously optimistic...
So I received my advance replacement directly from Surface support. While the fan did come on at a somewhat reasonable volume, I was able to do a full update (37 of them initially) including firmware, install Visual Studio 2013, and Office 2013 without the unit overheating and displaying the temp warning. One thing I noticed is that, while the unit was plugged in, the fan stayed on throughout the entire update/firmware process. The fan hasn't gotten as loud as my last few units.
Unfortunately, the advance shipment didn't come in the original packaging so I don't know its batch/lot number. Lot number is 1430 (located on the outside of the return box) But I'm going to do some further testing between the two that I have
to see if there are any obvious differences before sending the 3rd one back.
I was also given word that the Surface team is currently investigating the issue, so keep your fingers crossed.
8/6 - So far, it seems we have the following scenarios:
- There is a manufacturing issue with these particular batches due to a bad CPU yield, heat-sink, or fan. (need more info to validate)
- There could be a software/firmware issue causing the temps to rise and thus the fans to run blast even during idle/light processes. Although, I'm less certain this is the case, the low CPU usage and high temps seem to suggest otherwise.
- This could be tied to disk activity. I don't think it's the SSD hardware, given its placement being in the lower left quadrant of the device. However, this would also explain the low CPU usage and high temps given in the many cases where software is being installing, there is background indexing, or updates are being applied.
- If some people in the same batch aren't having issues, then maybe:
- They haven't discovered the issue because the temperature hasn't risen to the point of a nuclear reactor and/or there device hasn't given them the overheat warning.
- Or there is a problem but they're comfortable with the heat/noise generated and the device hasn't given them an overheat warning.
- Or they simply have a perfectly running device that never goes above 75-85C and is whisper quiet at all times during normal usage.
- If people in different batches are having issues, then maybe:
- The issue isn't tied to the batch/lot at all and the problem may widespread or be due to a general assembly problem (poorly set heat-sink for ex.)
- All Surfaces manufactured so far could potentially run hot as hot as 90C (highly doubted)
But there's definitely an issue. You're only supposed to get that overheat warning (thermometer symbol) in cases due to external factors like:
- You've left the device on inside of your backpack with screen at full brightness for an extended period
- You attempt to use the device after it's been heated from direct sunlight, perhaps from being in your car, etc.
- The unlikely case that you've modified the way your device performs (overclocking, fan, etc)
In any case, I think we still need a larger sample size to discover & validate the issue and determine how widespread it is. I only expect MS to recognize there is a problem if it proves to be more common than not.
8/4- Aventura In-Store ReplacementJust got yet another replacement from the Aventura store. They only had stock from the 1429 batch, but I decided to swap it out anyway. Same issues: Gets piping hot, loud fan w/minor activity & idle. Intel stress test peaks out at 92°C. Temp icon/shutdown while applying windows updates. Going to hold off awhile before replacing. :'(
If you're lurking, taking the time to help us out by posting your model, batch #, and any notes or comments you have would be quite helpful, whether or not your device is affected.
If you're getting a replacement, save the hassle and point them to this thread to help expedite your exchange.
Users with similar issues: If you have similar issues, reply with your model & lot number (located just above your serial number on the box; starts with 14)
| Date - User | Model | Has Issue? - Lot # | Notes |
| 8/2 - Jarem | i7 512GB | Yes - 1429 | |
| 8/2 - Jarem | i7-512GB (replacement) | Yes - 1428 | |
| 8/4 - Jarem | i7-512GB (replacement) | Yes - 1429 | Peak CPU temp: 92°C |
| 8/4 - SurfacePro3User | i7-256GB | Yes - 1428 | |
| 8/4 - MV010 | i7-256GB | Yes - 1429 | "When running only chrome and skype, with a 7% CPU usage and 34% RAM usage, it emits very high fan noise thus disturbing my skype call. " |
| 8/4 - AnthonyKageals | i7-256GB | Yes - 1429 | "It then wanted to install some updates and while installing the updates it started to get VERY hot. It eventually shut down with the temperature sign being displayed as you pictured above." |
| 8/4 - Nick Hymes | ??? | No - ??? | "I experienced some heat and a lot of fan usage on the first day of use after installing programs and files (possibly caused by indexing), however I am not<br> observing heat or fan operation now." |
| 8/4 - RobertHacker777 | i7-256GB | No - 1429 | "I hear the fan plenty but so far no overheat symbol and shutdown" |
| 8/4 - khairy72 | i7-256GB | Yes - 1428 | "I was casually browsing on the surface about 10 minutes ago and the fan went on full blast and the surface was HOT." |
| 8/4 - rinconmike | i7-256GB | No - 1429 | "I hear the fan plenty but so far no overheat symbol and shutdown." |
| 8/6 - Scott Hanselman | i7-256GB | Yes - 1429 | "Just got a temp and shutdown. Averaging between 65-80C." |
| 8/6 - khairy72 | ??? | Yes - ??? | "I have gone through 2 surface pro i7 models so far" |
| 8/6 - RobertHacker777 | i7-512GB | No - ??? | "I bought the i7 512GB version for my wife. No issues whatsoever! " |
| 8/6 - Sahas Katta | i7-512GB | Yes - 1428 | "Before the updates succeeded, my fans blazed at full speeds (louder than my desktop) and everything froze." |
| 8/6 - JonathanSharkey | i7-256GB | No - 1428 | "I've had no issues whatsoever" |
| 8/6 - Klankins | i5-256GB | No - 1423 | "The back gets hot but it seems like it is working like it should." |
| 8/6 - RobertHacker777 | i7-512GB (replacement) | Yes - 1430 | "...(my replacement batch) seems to be working just fine!!!!! YES!!!! HAPPY NOW!!!!"<br><br><br>Update 8/7: "has the SAME ISSUE! I have already processed a refund and purchased an i5, 256" |
| 8/6 - Your_Mom | i5-256GB | Yes - 1423 | "got so hot with light browsing I couldn't hold it" |
| 8/6 - Your_Mom | i5-256GB (replacement) | Yes - 1426 | "it gets excessively hot as well" |
| 8/6 - LaRae White | i7-256GB | Maybe - 1428 | "I don't want to say definitively that I'm having issues, but it does get quite hot and loud at seemingly simple tasks" |
| 8/6 - BellevueSteve | i7-256GB | Yes - 1429 | "two shutdowns with temp icon, preceded by loud and sustained fan noise during initial Windows Update OOB installs, then another sustained fan period (no shutdown but lower right back got hot) during<br> install of Visual Studio update 3." |
| 8/6 - adrianbli | i5-128GB | No - ??? | "haven't noticed any issues. it gets warm while charging, but really not very hot at all" |
| 8/7 - Antares Light | i5-128GB | Yes - 1424 | "Having the same heating issue with some simple game apps such as MS mahjong and MS treasure hunt (always); web browsing and one note (some times)" |
| 8/7 - GlennDoren | i7-256GB | Yes - 1428 | "whenever I have my real-time stock trading website up (in explorer or chrome--doesn't matter), the fan kicks in." |
| 8/7 - HL Brooklyn | i7-256GB | No- 1428 | "so far everything appears to be normal" |
| 8/7 - noteventhrice | i7-256GB | Yes - 1429 | "Getting the same issues, can't say how many times I've seen that thermometer symbol after windows crashing, but it's been terrible" |
| 8/8 - frogcjn | i7-512GB | Yes - 1430 | "when I was installing windows updates, it cannot turn on!!! After a while, I can turn it on. Then I found it is too noise with its fan running in a slow speed." |
| 8/8 - Kasco Jake | i7-512GB | Yes - 1429 | "...if i were holding the tablet, it would probably burn my hand if I didn't move it to another side with the amount of heat" |
| 8/8 - Piero00 | i7-256GB | Yes - <br>1429 | "It hasn't overheated yet but the fan runs extremely loud and the back gets very hot." |
| 8/9 - J. Branco | i7-512GB | Yes - 1429 | "While updates were being installed this morning during restart it showed thermometer, then shutdown - two times." |
| 8/9 - frogcjn | i7-512GB (replacement) | No - 1427 | "1. The new one does not have the sharp fan noise. (At least until now.)<br><br><br>2. When the sales boy installed windows update on the new one, no high temperature errors." |
| 8/9 - Wes Preston | i7-256GB | Yes - 1430 | "Fan volume cranked up almost immediately on the i7/256 I pulled out of the box today. Lot 1430. Loud fan and very warm back, but not to the point of the temp alert or shutdown yet" |
| 8/9 - Jarem | i7-512GB (replacement) | No - 1430 | "My replacement from Surface support has yet to exhibit the issue. Read 8/9 update above." |
| 8/10 - Dan Schwartz | i7-256GB | Maybe- 1428 | "Had high heat/fan issues the first few days but since the recent updates I haven't had those problems." |
| 8/10 - RKB-Washington D.C. | i7-256GB | Yes - 1428 | "My new ( just bought it today and spent the day setting it up) cycles from high noise to low noise irrespective of the load I am putting on the CPU. " |
| 8/10 - f4denz | i7-256GB (replacement) | No - 1429 | "at no time did it get even close to the heat that I experienced daily with my original Pro" |
| 8/10 - nitehawk_967 | i5 -128GB | Yes - <br>1423 | "...my **'host task for windows process'**revs up to 25-30% cpu. and the right hand corner get hot to the touch and fans whir<br> like crazy" |
| 8/12 - kslogan | i7-256GB | No- 1427 | "Has not overheated, but fan frequently runs louder than expected even when experiencing light load. None of the Surface Pro 3 i5 or Surf Pro 2 i5 machines have comparable fan noise." |
| 8/12 - DilrajSaini | i7-512GB | Yes -1429 | "Get loud and hot while running AV scan. Skype hangs. Will try returning it." |
| 8/12 - Luis Mitchel | i5-128GB | No - ??? | "I tried to restore it but it overheated and stop working again, so I put it near the air conditioner and it restored successfully. I installed the updates manually but I didn't install the update from<br> 07/08/2014 (July) and the new 08/12/2014 (August). Now my SP3 is working as expected and it doesn't overheat." |
| 8/15 - StephenW7 | i7-512GB | Yes -1428 | "After trying to use the unit last night, I decided I'm going to return the unit. It's just way too hot to hold, and way to noisy." |
| 8/16 - The Cool Dude | i7-512GB | No - 1429 | "It's a little warm but that's about it. Streaming movies/TV shows from my NAS work fine without issue. No heat. No noise." |
| 8/16 - surfacepro3runninghot | i7-256GB | Yes - <br>1431 | "Fan is quite but it runs hot. Seems design issue . Mine is going back." |
| 8/16 - LO_CP | i7-256GB | Yes - <br>1429 | " doing the normal windows updates the fan was going crazy and it got really hot in the upper right where the fan is" |
| 8/19 - jl33t | i7-256GB | Yes - 1429 | The fan comes on and it's seriously the most menacing thing I've ever heard to come out of an electronic device. I can no longer use this in class to take notes since it's so disruptive. |
| 8/19 - Chipgoon | i7-256GB | Yes - <br>1429 | Machine was quite hot after running all of windows updates, and firmware update would not install until machine cooled down. But haven't had any thermal shutdowns yet, CPU throttling manages the heat<br> but reduces performance significantly. |
| 8/19 - Imaohw | i7-512GB (replacement) | Yes - <br>1432 | As soon as the SP3 starts to get warm ( which is all the time using video conferencing software) the fan comes on the microphones pick up the fan noise. This makes it very difficult for the other party<br> on the call to hear me. |
| 8/20 - Universeman | i7-512GB | Yes - 1429 | Didn't really have these issues until I installed the August firmwares/patches. Last night was my first overheat and temp warning shutdown, while I was re-applying patches after doing a system reset<br> in an attempt to troubleshoot a battery drain. |
| 8/20 - Brad Groux | i7-512GB x 3 | Yes - 1459 | I have four 512GB Core i7 SP3 from lot 1459. Three of the four have the issue. All four were purchased on launch day (08/01/2014) from the Houston Galleria store. |
| 8/20 - Brad Groux | i7-512GB (replacement) | Yes - <br>1522 | I have one 512GB Core i7 SP3 from lot 1522, and it has the issue. It was a unit swap at the Houston Galleria store yesterday, 08/19/2014. |
| 8/20 - Bloodlive | i7-256GB (replacement) | Yes - 1429 | "Loud Fan noise, Overheating and battery lasting 3-4 hours."..."I called Microsoft support, I referred them to this thread and they told me<br> we are a minority." |
| 8/20 - JohnBarboni | i7-256GB | Yes - ??? | "If I download something (anything) the fan kicks into overdrive and the back of the device gets hot to the touch. If I play a 3D game it shuts down and while it's off I get the thermometer until it cools<br> down enough to restart..." |
| 8/20 - KevinAdamsTMG | i7-256GB | Yes - <br>1429 | "Me too, excessive heat, (too hot to touch, and too hot to leave on lap) and the noise of the fan is unbelievable..." |
| 8/21 - SteveH_250 | i7-512GB | Yes - 1430 | "same issue for me: with light internet browsing (e.g. youtube videos) unit gets smokin' hot just behind the windows logo, and the fan comes on full blast" |
| 8/21 - 206realestate | i7-256GB | Yes - 1429 | "I have similar issues Surface Pro 3" |
| 8/22 - KenKen Yen | i5-128GB | Yes - 1430 | "Sh*t burns really bad whenever I play games and it goes completely volcanic when I play Project Spark." |
| 8/22 - YoshiJL | i5-256GB | Yes - 1429 | "has heat issues"..."just got it out of box. Might be charging issue" |
| 8/22 - sj_canada | i7-256GB | Yes - 1429 | "After installing all updates on 2014-08-21, it currently runs very hot in spite of loudly operating fan even when working on simple tasks (Internet Explorer, OneNote, file transfers). Battery draining<br> faster than expected." |
| 8/22 - Pamsaja | i7-256GB (replacement) | Yes - 1431 | "First I7 256 1428 overheating and fan noise, I returned it and bought the i7 256 1431 online ( replacement) the overheating problem is worse, i am thinking in return it and forget about the surface<br> and Microsoft" |
| 8/22 - STep_001 | i7-512GB | Yes - 1429 | "My system fan loudly and furiously spins up it then overheats and I get the same thermometer icon right before it shuts down." |
| 8/22 - DarrellGarrison | i7-512GB (replacement) | Yes - 1433 | "As soon as I had it up and running, the back got extremely hot, and the fan was going nuts. What was I doing? Running a YouTube video as a test. Same issues as my current unit. I already called<br> support and am shipping the replacement back." |
- Edit 8/3: Added purchase sources
- Edit 8/3: Added date/lot number for initial order
- Edit 8/4: Added user lot number table
- Edit 8/4: Added notes to table / formatting. Updated w/third SP3
- Edit 8/6: Added yes/no issues to table, more entries
- Edit 8/7: more entries, removed model numbers.
- Edit 8/8: more entries
- Edit 8/9: Added update on 4th Sp3
- Edit 8/10: more entries
- Edit 8/12: more entries
- Edit 8/14: more entries
- Edit 8/16: Update on fourth unit added. more entries
- Eidt 8/19: more entries
- Edit 8/20: Update on fourth unit :(, more entries
- Edit 8/22: more entries (not looking too good)
- Edit 12/12: ReAdded table showing users with similar heating/noise issues that was removed.
2014-12-31T04:38:58+00:00 -
@CmdrKeene 90,631 Reputation points Volunteer Moderator2014-12-31T04:42:19+00:00 Yeah that would happen with any laptop. That's normal, that's why it has the fan :)
2014-12-31T12:14:33+00:00 I will try and confirm your request; it honestly wouldn't surprise me though. Also posted again later stating that the fan did not run while using the screen saver on battery.
Thanks Dmillerzx. It will help me a lot.
Incidentally, I had an SP2, and it never ran the fan under the same conditions of the SP3. I only heard the fan after a good session of Asphalt 8, but never during installation time, or xbox music utilization.
Cheers and happy new year to all.
/Flavio
2015-01-07T17:51:32+00:00 Hello Cmdr Keene,
I follwed the thread for a while. And similar Posts here too.
I recommend Microsoft to hear to their customers better. Somewhere in the depth of SP3 and Win 8.1 and some apps are bugs or not well done Hardwaredesign or any combination of that. And sometimes there are unrealistic customer espectations.
But please stop telling everytime that it is normal. And please stop answering generic stuff...
It is not "normal", because:
I have a SP3 here, I am typing with IE open. Chrome (!) is open too, several URLs are opened too. I have Excel, Outlook, Word, pdf-Viewer App opened and Windows Explorer opened.
My SP3 is right now docked within the SP3 Dockingstation, which I have bought yesterday, without Docking I have the same: NO FAN IS ON. It is completely silent and it is not very hot. The upper right back is a little bit warm, completely normal!!
Sometimes the fan starts, but not on full Speed, not for Long time.
I call this normal behavior!
But before some Updates ago I got that Problem too. Maybe the updates solved the Problem, maybe the choose of energy plan (see some Posts earlier). One App from Microsoft is not very polite to the processor: OneDrive Sync is definitivly heating up the System and File Indexing too... And Windows Update itself is heating up too.
Conclusion: I love my SP3 when it is silent and in "normal mode". I hate the fan's noise. Hey Microsoft: work on a more silent fan, because right: SP3 needs a fan, but it could have a more convinient sound. My SP3 did cost 1999 EURO, much Money. And yes: I love my SP3, but my Mac Book pro has a much more better Hardware-Design! -Same Price.
And Microsoft: please improve Indexing, OneDrive, Windows Update ;) they produce useless heat.
And Mr. Keene: Normal is silent, right now, here on my SP3. Not a single fan turn while writing this post.
2015-01-10T21:47:25+00:00 So I'm throwing my own two cents into this convo after reading it all (yah, all 86 pages...).
Specs: Surface Pro 3, i7, 256GB, Lot 1447.
Maybe I'm jumping the gun here because I've been really sick so I'm already cranky, but my brand new SP3 is making me angry. I got it in the mail Thursday (after a 3 week battle with UPS (who lost the darn thing). At initial setup, it ran hot almost immediately with a obscenely loud fan and almost burned my hand. The fan was even running in high in SLEEP MODE.
I then did all of the updates it needed, I've installed Malwarebytes and AVG, and I installed CoreTemp to monitor the temperature. It has seemed to settle down a bit, so for the past while these are the temps I've observed, how do these look, pretty normal? I tried to keep things to just whatever I was testing, CoreTemp, and Notepad for note taking.
The SP3 was not plugged on, running battery only.
Actual Temperature in my room- 17C
20 minutes of Firefox 1 tab- browsing Reddit - 34C - 42C
10 minutes of AVG virus scan running (nothing bad found) - 90C
20 minutes of Firefox watching youtube video - 51C average on the first vid and 70C on the second for about a minute which locked up youtube for the minute until the temperature dropped back down and the video resumed
20 of Firefox browsing tumblr - 46C - 64C
20 minutes of scribbling in 20 layers of Manga Studio 5- 50C - 70C
And the big one... 10 minutes of 7 youtube videos running at the same time at full volume - 70C - 80C
So... after all of that the worst was the Virus scan oddly. It seems like it's doing better... oh and it used 50% battery life in 2 hours doing all of that. The fan kicked on every time it passed about 60C and at 50C is silent. Its at 15% battery so I needed to plug it in. I did so, and the average browsing temp jumped to 42C.
Then I decided to watch some videos while it charged. It doesn't like that. 75-85C during a single four minute video while plugged in. Does this thing just work better on battery alone? Is that normal to be hotter while plugged in?
I just... I'm not sure. I really don't want to have to try and send it back. I got extended warranty and everything, that's not a problem, but... it was a nightmare getting it here because of UPS.
Anyways, that's just my experience so far... I hope it's going to work for me, I really do, because otherwise I do love the unit. It's fast and drawing on it is soooo nice. But I don't want to risk frying anything with it...
