completely reinstalled windows incl. performing deleting all files on my HD. No apps or programs were installed. Ran all windows updates. Battery still drained. :(
Battery Drains While Shutdown
I have read many posts and made many attempts to correct this problem without any success.
I was traveling for 3 months and when I returned the battery was completely dead.
Also, each night since my return, the battery drains as much as 12% overnight while shutdown.
I have all MS updates but the problem continues.
Please advise.
THX! :)
2018-06-07T05:32:48+00:00 -
2018-06-07T05:41:31+00:00 completely reinstalled windows incl. performing deleting all files on my HD. No apps or programs were installed. Ran all windows updates. Battery still drained. :(
2018-06-07T07:17:27+00:00 I had the same problem with my 2016 Surface Pro 4 with the batter drain. I also had a problem with the screen shaking to a point that it was unreadable. Microsoft, after 6 months of trying all kinds of fixes replaced my SP4. I have been working with it about two weeks and notice that the battery drain is very small now. I can leave it for a few days and the battery is still in the 90% or better range. That is wonderful.
Cheers,
JerryBangkok
2018-06-11T21:34:22+00:00 So I don't get. I create a thread regarding a battery drain issue. MS Agent asks for a sleep report. I provide 2 of them, and instead of getting a response, I get my thread merged with another thread having similar issue. Yet, no further response from MS Agent afterwards. I get it, it's probably easier to keep similar topics in one thread, but it also makes it look like this is not a prevalent issue when everyone's issue is merged into one thread. At least give me a follow up to what you asked for and what I provided. Each evening, I shut down at 100% and the following evening I am starting at 90%.
2018-08-19T02:33:41+00:00 Guys..
This is my 2 cents worth.
It's frustrating. I purchased my Surface Pro 4 in May 2017.
It was a new unit and I was excited with it. Soon enough I realized that there was a serious flaw with the Battery Drain. I began to check and the Q&A went back as far as 2014 as I can see. Could be further back though. Same Q&A. I also tried all those suggestions given. NOTHING seems to work. So I am totally disappointed. I'd probably just cut my losses and move on with another brand. Sadly this series is NOT a thumbs up for me.
But I must say that I am very pleased wit ALL the other features available. It's only the battery drain thing. I cannot predict when I will be left high and dry and that is not good.
Sad Customer.
Brian E.
