Constant BIOS Boot on Surface Pro 2
2014-03-14T11:05:36+00:00
I had just received my SP2 from the Microsoft Store two days ago and decided that I would go out and buy a Bluetooth Mouse. The mouse connected once and failed, then I realised that the Bluetooth of my Surface has stopped functioning completely and I wasn't even able to detect my phone. Therefore I decided to "Refresh" my PC and reset most of the settings back to normal.
However, during this refreshing period, Surface entered the screen below and halted all progress. I played around with it, one way of going around the problem was to "Delete all Secure Boot Keys", "Exit Setup", then it would restart to a red screen, display this page and then I select "Install Default Secure Boot Keys". After that it would reboot like normal.
The problem is that now it would constantly show this screen during boot no matter what I do. Is there a way to fix this without sending my Surface back to Microsoft?
2014-03-15T23:15:23+00:00
Hello Jeff Skully,
Sorry to hear you are having issues booting your Surface Pro 2.
We would like to help, If you are not able to get past the UEFi screen, please try the following steps.
  1. Power off the Surface.
  2. Connect the charger.
  3. Press and hold volume up + power for 20 seconds.
  4. Release power up and power button.
  5. Wait 30 seconds.
  6. Try to power on your Surface.
If this does not resolve the issue, you will need to contact support.
Please let us know if that resolves the issue.
Best regards.
2014-03-20T18:54:29+00:00
Greetings Mark,
Sorry to hear about your Surface Pro 2 booting into the UEFI. I'd suggest putting your Surface in for exchange using the Self-Service page.
2014-05-21T16:35:23+00:00
Greetings Juan schinocca,
Thank you for posting to the Microsoft Surface community. I'm sorry to hear that your Surface Pro 2 will only boot to the UEFI screen. There's a few things we can try to get your Surface Pro 2 to boot back into Windows.
  1. Try the Two-Button Shutdown
  • With your Surface powered off, hold the Volume Up and Power button for 15 seconds. Once 15 seconds have passed, release the buttons. Wait 5 seconds then press the Power button to power on.
  • You can try this option a few times to see if your Surface will boot into Windows
  1. Run the battery completely to zero (0%) by leaving it on the UEFI screen until it shuts off.
  • Once it shuts off, press the Power button to turn it back on until it will no longer power on, give a battery symbol, or even light the screen.
  • Once it will not power on, connect the Power Supply and let it charge then try and power on the Surface Pro 2.
If your Surface powers on and boots into Windows, please download and install this KB.
If you cannot get your Surface Pro 2 to boot into Windows, please contact Surface Technical Support.
2014-03-25T22:57:10+00:00
Greetings FM_1970,
Sorry to hear that your Surface Pro 2 is stuck at the UEFI screen. We’d like to assist in getting your Surface working again. Please go to the Self Service page, select the Problem with a device or cover option, select your Surface Pro 2 or add a device, and finally select Turns on but won’t start up.
Please fill out the problem box, and click on the option to create a service order.
2014-08-30T01:05:16+00:00
Hi Ken645,
Thank you for visiting the Microsoft Community with your inquiry! We value the time you have taken to post and contribute. I am sorry to hear that you get the UEFI menu every time you power on your Surface Pro 2. I can certainly see why this is confusing and bothersome, so please know I will try my best to assist and guide you in the right direction.
Whenever you need to access the UEFI menu, you must press and hold the volume-up button on your Surface. For this reason, we ask you to please verify and test that the volume-up button on your Surface is not stuck and it is indeed working properly.
You can do several things in order to try this: accessing any video site, playing music to checking if you are indeed able to control the volume properly, and also testing the volume with the Type Cover and without the Cover.
If the volume-up button is working properly, please check the following:
  • Make sure you have all and latest Windows updates installed. Please manually check for updates and install all that are available:
  • **Desktop> Swipe for Charms> Settings> Control panel> Windows update> check for updates> install.**Restart between layers of updates, even if not prompted to.  Restart twice after the last update installs.
  • Additionally, try holding down the "Volume UP" and the "Power Button" at the same time for about 15 to 20 seconds.  It should do a reboot and if no activity, release and 'click' the power button one time.
If the button is indeed stuck, then we suggest you contact our Technical Support Team. Depending on what is most convenient for you, you can:
  1. Open a service request yourself, using our **Online Service Center**
  2. Contact our Technical Support team**here**
I am also including a support article that should be helpful:
We hope this information is useful! Please keep us posted and let us know what happens!
We are here to help and we will be looking forward to your response!
Best Wishes,
2014-08-27T18:08:20+00:00
Greetings, Cat yoga,
Thank you for the reply.
If you are using a Pro device, please try the following solutions:
If your Surface still won’t turn on, it needs service. To request service, see Surface Online Service Center. You can also contact our live Support
Best Regards,
Clare
2014-05-19T23:25:08+00:00
Greetings all,
If your Surface Pro 2 is getting stuck at the UEFI, please download and install the hotfix here.
2014-04-08T23:24:58+00:00
Greetings Over Drive,
I'm sorry to hear that your Surface Pro 2 is stuck at the UEFI screen. I'd like to assist in getting your Surface working again. Please go to the Self Service page, select the Problem with a device or cover option, select your Surface Pro 2 or add a device, and finally select Turns on but won’t start up. Please fill out the problem box, and click on the option to create a service order.
2014-03-30T12:25:03+00:00
Unfortunately I had no success with resolving the issue even with the assistance from Microsoft Technical SPT. Surface PRO has been returned to Microsoft and now awaiting the new one. Hopefully same issue will not occur again?
110 additional answers
    2015-05-04T16:14:41+00:00
    Hi Hoang Gau,
    We are sorry to hear that you are not able to turn on your device. We understand this is a frustrating situation for you. If you'd like to continue troubleshooting before send in the device for a service,
    there are few things you can try.
    • 2 button shutdown without any accessories
      1. Remove ALL accessories including a SD card
      2. Let the device charge for 4 hours
      3. Press and hold the Volume-up button and the Power button on your Surface at the same time for at least 15seconds, and then release both.The screen may flash the Surface logo, but continue holding the buttons down for at least 15seconds.
      4. After you release the buttons, wait 10 seconds.
      5. Press and release the power button on your Surface to turn it back on.
    • Refresh using a USB recovery Drive
      1. Download a recovery image
      2. Create a USB recovery drive
        • Note your USB has to be in FAT32 format and at least 16GB
      3. Refresh from USB recovery media
    Kind regards,
    Clare
