Surface Pro 3 - Missing Surface Pro Touch Controller Firmware after reimage
2014-06-26T13:57:29+00:00
MDT 2013 - Windows 8.1 all updates.
Download surface Pro 3 firmware and driver http://www.microsoft.com/en-us/download/details.aspx?id=38826 to mdt 2013 out of box driver. Reimaged it, but missing only one and most essential driver
UEFI\RES_{e5fff56f-d160-4365-9e21-22b06f6746dd}&REV_0
without this driver, surface pro is just untouchable...can anyone help me to find this driver.
thanks in advance...
2014-06-27T23:39:57+00:00
Hello Orionbelt,
I'm sorry that you are experiencing the inconvenience of this missing driver on your Surface Pro 3. We're here to help.
As this is a pretty technical issue related to a re-image of the device, we suggest you contact our Technical Support Team to help you with this in real-time. You can contact them through chat or phone here.
Thanks for reaching out to us, and please contact us again if you have any other questions.
Best Wishes,
Zack_T
126 additional answers
    2014-12-02T01:30:14+00:00
    solved, at least for me. after 3 restores, and repeated attempts of reinstalling the drive it seems to work. after reading another thread on this issue, the firmware wont take unless the battery is at 100% (99% and charging is not good enough). im keeping my fingers crossed, but no more yellow triangle. if it suddenly comes back, I might try to see how far I can Frisbee it.
    2014-12-03T02:55:12+00:00
    I have the same issue with the touch firmware and it's the 2nd replacement that MS sent to me to resolve this issue with Missing Surface Pro Touch Controller Firmware. Where did you get the info about the fact that battery has to be 100% charged?
    2014-12-03T04:34:14+00:00
    OK, I tried it with a 100% charge and the yellow triangle is finally gone! That's totally nuts! Let's see if it holds over time.
    Bye.
    2014-12-03T11:02:02+00:00
    Bye.
    Hi, what did you do exactly when you say I tried with a 100% charge? Did you reset your Surface or uninstall and reinstall the firmware update?
    Ccote
