Surface Pro 3 - Missing Surface Pro Touch Controller Firmware after reimage
2014-06-26T13:57:29+00:00
MDT 2013 - Windows 8.1 all updates.
Download surface Pro 3 firmware and driver http://www.microsoft.com/en-us/download/details.aspx?id=38826 to mdt 2013 out of box driver. Reimaged it, but missing only one and most essential driver
UEFI\RES_{e5fff56f-d160-4365-9e21-22b06f6746dd}&REV_0
without this driver, surface pro is just untouchable...can anyone help me to find this driver.
thanks in advance...
2014-06-27T23:39:57+00:00
Hello Orionbelt,
I'm sorry that you are experiencing the inconvenience of this missing driver on your Surface Pro 3. We're here to help.
As this is a pretty technical issue related to a re-image of the device, we suggest you contact our Technical Support Team to help you with this in real-time. You can contact them through chat or phone here.
Thanks for reaching out to us, and please contact us again if you have any other questions.
Best Wishes,
Zack_T
126 additional answers
    2015-02-04T02:29:44+00:00
    Oh, and do you even try the reboots when it fails the initial time. Or do you just go back in and delete the driver, etc. immediately after you see it fails?
    2015-02-07T17:46:32+00:00
    I finally quit trying and called support.  They said to go back to the Microsoft store and there has to be at least one with the proper hardware id.  I did this and the first tech I got this time actually had seen this pop up on a few different machines he had updated.  He went to the back, pulled out another device for me and felt confident it had the proper hardware id.  And sure enough, it did!  Now I'm all updated and running just fine.  I can finally use the Surface Hub app.  Good looking out Microsoft!
    2015-03-03T08:22:59+00:00
    Rubenkz,
    It is an issue with the firmware update, so upgrading the operating system or the driver probably isn't going to help.
    Microsoft has finally acknowledged the problem in this MSKB article (http://support.microsoft.com/kb/3024327), but they haven't posted a fix yet.  At this point you have three options:
    1. Wait for a fix to be posted in MSKB 3024327
    2. Keep trying to install the firmware update over and over again and eventually it will take (according to Microsoft it is a timing issue)
    3. Return the Surface device to MS and get a different one and hope for a different batch that doesn't contain the faulty firmware
    -James
    I'm taking the fourth option. Since this yellow triangle in the Device Manager seems to cause no malfunction in the usage of the device, including the touchscreen, I'm ignoring it and continue to enjoy using my Surface Pro 3 on a daily basis.
    Bye.
    For you, may be. For others like me, everything in SP3 works just fine except touch and pen (pen works sometimes).
    It keeps failing to install the firmware after 20%.
    2015-03-31T02:54:22+00:00
    Appears this is fixed, at least in my case.  Took the latest firmware update, and it took a few minutes to update next boot (rather than seconds).  Still hadn't cleared the device manager warning.  A couple days later it ran again during boot..that time it stuck, warning is gone.  Maybe I'm lucky.
