Surface Pro 3 - Missing Surface Pro Touch Controller Firmware after reimage
2014-06-26T13:57:29+00:00
MDT 2013 - Windows 8.1 all updates.
Download surface Pro 3 firmware and driver http://www.microsoft.com/en-us/download/details.aspx?id=38826 to mdt 2013 out of box driver. Reimaged it, but missing only one and most essential driver
UEFI\RES_{e5fff56f-d160-4365-9e21-22b06f6746dd}&REV_0
without this driver, surface pro is just untouchable...can anyone help me to find this driver.
thanks in advance...
2014-06-27T23:39:57+00:00
Hello Orionbelt,
I'm sorry that you are experiencing the inconvenience of this missing driver on your Surface Pro 3. We're here to help.
As this is a pretty technical issue related to a re-image of the device, we suggest you contact our Technical Support Team to help you with this in real-time. You can contact them through chat or phone here.
Thanks for reaching out to us, and please contact us again if you have any other questions.
Best Wishes,
Zack_T
126 additional answers
    2015-01-22T01:01:15+00:00
    No joy with the first tablet I've tried.  It was a replacement one that was sent after I opened a case with MS.
    The Touch Controller Firmware version is the same, so it doesn't look like it was updated with this release.  :(
    We have some i7 versions of the Surface that haven't exhibited this issue...only the i5's.  Is that anyone else's experience or just our luck of the draw?
    2015-01-29T03:05:37+00:00
    I am having a problem where the exclamation point is showing up and I can't get it to go away. I've tried disabling and reenabling and searching for driver updates online, etc. I am running windows 10 tech preview, which may not help much. I had this problem in 8.1 as well.
    2015-01-29T05:38:44+00:00
    Rubenkz,
    It is an issue with the firmware update, so upgrading the operating system or the driver probably isn't going to help.
    Microsoft has finally acknowledged the problem in this MSKB article (http://support.microsoft.com/kb/3024327), but they haven't posted a fix yet.  At this point you have three options:
    1. Wait for a fix to be posted in MSKB 3024327
    2. Keep trying to install the firmware update over and over again and eventually it will take (according to Microsoft it is a timing issue)
    3. Return the Surface device to MS and get a different one and hope for a different batch that doesn't contain the faulty firmware
    -James
    2015-01-29T11:26:41+00:00
    Rubenkz,
    -James
    I'm taking the fourth option. Since this yellow triangle in the Device Manager seems to cause no malfunction in the usage of the device, including the touchscreen, I'm ignoring it and continue to enjoy using my Surface Pro 3 on a daily basis.
    Bye.
