Surface Pro 3 - Missing Surface Pro Touch Controller Firmware after reimage
2014-06-26T13:57:29+00:00
MDT 2013 - Windows 8.1 all updates.
Download surface Pro 3 firmware and driver http://www.microsoft.com/en-us/download/details.aspx?id=38826 to mdt 2013 out of box driver. Reimaged it, but missing only one and most essential driver
UEFI\RES_{e5fff56f-d160-4365-9e21-22b06f6746dd}&REV_0
without this driver, surface pro is just untouchable...can anyone help me to find this driver.
thanks in advance...
2014-06-27T23:39:57+00:00
Hello Orionbelt,
I'm sorry that you are experiencing the inconvenience of this missing driver on your Surface Pro 3. We're here to help.
As this is a pretty technical issue related to a re-image of the device, we suggest you contact our Technical Support Team to help you with this in real-time. You can contact them through chat or phone here.
Thanks for reaching out to us, and please contact us again if you have any other questions.
Best Wishes,
Zack_T
126 additional answers
    2014-12-13T14:58:38+00:00
    Yes? I think so! I really like the device and it works fine even with the "yellow triangle."  However, if you get a replacement I would just try to make sure that it doesn't have the REV_1A31A36 Hardware ID.
    It's just really frustrating that MS is not addressing this issue with it's customers.
  2. Deleted
    2014-12-14T22:58:37+00:00
    Lot no 1428.
    2014-12-18T20:39:56+00:00
    I'm havungnthe same issue too! It stinks trying to type on screen and i need my keyboard! Anyone have any new updates to fix? Ms tech support couldn't help.  btw, I'm really regretting getting this, nothing but problems.
