Surface Pro 3 - Missing Surface Pro Touch Controller Firmware after reimage
2014-06-26T13:57:29+00:00
MDT 2013 - Windows 8.1 all updates.
Download surface Pro 3 firmware and driver http://www.microsoft.com/en-us/download/details.aspx?id=38826 to mdt 2013 out of box driver. Reimaged it, but missing only one and most essential driver
UEFI\RES_{e5fff56f-d160-4365-9e21-22b06f6746dd}&REV_0
without this driver, surface pro is just untouchable...can anyone help me to find this driver.
thanks in advance...
2014-06-27T23:39:57+00:00
Hello Orionbelt,
I'm sorry that you are experiencing the inconvenience of this missing driver on your Surface Pro 3. We're here to help.
As this is a pretty technical issue related to a re-image of the device, we suggest you contact our Technical Support Team to help you with this in real-time. You can contact them through chat or phone here.
Thanks for reaching out to us, and please contact us again if you have any other questions.
Best Wishes,
Zack_T
126 additional answers
    2014-12-12T19:00:18+00:00
    That's my question as well (is this just a glitch in Device Manager or with the driver?).  My device (2nd one) has worked fine even when the Pro Touch Firmware has the yellow triangle.  I've done the 100% charged and all that you have mentioned as well....to no avail.  I've done the hard reset, wiping everything from my device ( :( ) as instructed from MS.  I ended up doing that again (since I didn't have anything to lose at that point). I haven't done the last updates because I didn't want the yellow triangle there!  I was told that I would get another (!) replacement if the hard reset did not work.  However, I haven't heard anything back via email from Microsoft (we were communicating via email).
    I feel for those folks that haven't made it to this thread and are left out of the loop of what is going on as when you call/chat with MS support, they don't tell you that this is an ongoing problem! It should be shared with all customers!
  2. Deleted
    2014-12-12T20:29:11+00:00
    "You should see "Surface Pro Touch Controller Firmware" listed in device manager without the yellow triangle to confirm that it has been installed successfully."
    That is what happened. Driver installed perfectly.
    Great for you.  Can you please check the hardware ID that you have?  Double-click on the "Surface Pro Touch Controller Firmware" and look under Details tab.
    Here is the Hardware Id you requested:
    UEFI\RES_{e5fff56f-d160-4365-9e21-22b06f6746dd}&REV_1AA1B42
    Still no more yellow triange and all software updated.
    Hope you have similar luck.
    Now to address my pen not showing up in the bluetooth setup:
    After doing some online research it would appear that a possible explanation would be that the button batteries discharged somehow during transit.
    I will post when I have tested this theory.
    Busy time of year so I may not have results right away.
    2014-12-12T21:31:03+00:00
    OK, I did the 100% charged up and still plugged in and uninstall the yellow triangle firmware and then power down thing. After powering up, there is no yellow triangle to be seen and the names of the firmware are now different - there is no touch firmware
    • there are still four. The touch screen works just fine, of course - it always has for me no matter what the name of the firmware is or if it had a yellow triangle.
    Is this just a silly problem with Device Manager reporting, or maybe some weirdness of some low-level driver accurately reporting its health wrong? My Surface Pro 3 has worked just right since the first day I had it - yellow triangles and all.
    Bye.
    You basically just removed the new firmware update and put back the factory version.  However the triangle will re-appear next time Windows Update makes another attempt to install the 11/18 firmware.  There is no resolution until Microsoft can issue a new version.  In the meanwhile, it does not appear to impact any functionality.  It's just not using the latest firmware.
    That's a possible explanation. Yes, the dreaded yellow triangle returned to the now renamed touch firmware when I forced a full update.
    I have some seemingly naïve questions: Why does an old driver (firmware) get installed when I uninstall the yellow triangle offender firmware? Shouldn't Microsoft be installing the most recent driver (firmware) when PNP notices a missing one? Or does this firmware somehow not lend itself to the idea that there is "the latest" and the only way it exists in the form of the "old one" and then an update patch? That's not how things have been in this realm.
    So Microsoft - where's the fix?
    Bye.
