Surface Pro 3 - Missing Surface Pro Touch Controller Firmware after reimage
2014-06-26T13:57:29+00:00
MDT 2013 - Windows 8.1 all updates.
Download surface Pro 3 firmware and driver http://www.microsoft.com/en-us/download/details.aspx?id=38826 to mdt 2013 out of box driver. Reimaged it, but missing only one and most essential driver
UEFI\RES_{e5fff56f-d160-4365-9e21-22b06f6746dd}&REV_0
without this driver, surface pro is just untouchable...can anyone help me to find this driver.
thanks in advance...
2014-06-27T23:39:57+00:00
Hello Orionbelt,
I'm sorry that you are experiencing the inconvenience of this missing driver on your Surface Pro 3. We're here to help.
As this is a pretty technical issue related to a re-image of the device, we suggest you contact our Technical Support Team to help you with this in real-time. You can contact them through chat or phone here.
Thanks for reaching out to us, and please contact us again if you have any other questions.
Best Wishes,
Zack_T
126 additional answers
    2014-12-10T21:30:28+00:00
    I'm inclined at this point to agree with you! I'm keeping what I have (my 2nd one) until they get the issue corrected. My machine works at the moment. When I get home I'm going to uninstall that driver and not perform that particular update until MS fixes it! So frustrating!
    2014-12-10T21:39:24+00:00
    Mine seemed to work okay too. But then I had odd problems, my keyboard wouldn't work, pen was sporadic and the network on the dock didn't work.
  3. Deleted
    2014-12-11T01:28:29+00:00
    Thank you for your suggestion. I too, had the yellow triangle until I followed your step:
    "What got rid of the yellow triangle from the firmware in Device Manager was to be sure the battery was charged to 100%, and leaving the charger connected, I uninstalled the offending yellow triangle firmware (deleting the driver)."
    Deleting the driver option is what I hadn't done in my previous attempts to remove triangle.
    Also, my next step differed from yours in that I simply restarted surface pro 3 after removing firmware and deleting driver.
    It booted up perfectly and without the yellow triangle!
    I have to say that the computer seemed to function perfectly even with the yellow triangle but I just didn't like seeing it.
    The only issue I have left is with my surface pro 3 pen.  It seems to work fine but does not show up in the list of bluetooth devices.  Also, it doesn't open OneNote when clicking the top of pen nor does it do a screen capture.
    Any suggestions would be appreciated.
