2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-07-31T17:52:54+00:00
    Add me to the list. My battery is effectively dead. Charge time is 2 minutes from 0% - 100% and removing the tablet from the dock or from the power cable will instantly power it off.
    Only Microsoft could manage to transfer the issues they bring with their software (namely, inexplicable problems only Microsoft products suffer from), to a hardware platform.
    2016-07-31T18:47:19+00:00
    They want 99.00 just to talk, is there anywhere else I can report the problem with the battery? I am only 5 months out off warranty and the surface says it is 100%  charged until I remove it from the charger. I have tried all the help pages and suggestion listed in the community but nothing is working. Thank You
    2016-07-31T23:13:32+00:00
    I'm not about to argue with Microsoft, but I personally think that the claim that it's SOFTWARE related is bogus, and Microsoft just trying to get out of a costly recall.
    If this really was SOFTWARE related, then it should affect Windows 10 users, as that appears to be when the issue cropped up, and didn't show up on Windows 8 or 8.1.
    However, I was having some issues, in addition to the battery, and did a full factory reset of my Surface Pro 3, and guess what? I have extremely low battery capacity on Windows 8.1:
    Installed batteries
    Information about each currently installed battery
     BATTERY 1
    NAME X898289
    MANUFACTURER SIMPLO
    SERIAL NUMBER 1163532804
    CHEMISTRY LION
    DESIGN CAPACITY 42,157 mWh
    FULL CHARGE CAPACITY 1,832 mWh
    CYCLE COUNT 286
    At this point I'm extremely glad that I paid for an extended warranty on my Surface, have already requested warranty service, and have already received my shipping package and return information. I am going to keep monitoring this situation, but at this point I'm going to be extremely hesitant in wanting to get another Surface until Microsoft actually owns up to the issue (I still think that the Surface is the best portable all in one available).
    2016-07-31T23:46:06+00:00
    Same problem here, Greg.  Glad to know you guys are on it.  In looking at the date the degradation started - late May, seems to coincide with latest BIOS update-- perhaps that's the cause?
    NAME X898289
    MANUFACTURER SIMPLO
    SERIAL NUMBER 1161042436
    CHEMISTRY LION
    FULL CHARGE CAPACITY 7,706 mWh
    CYCLE COUNT 81
    SYSTEM PRODUCT NAME Microsoft Corporation Surface Pro 3
    BIOS 3.11.1450 05/27/2016
    OS BUILD 10586.494.amd64fre.th2_release_sec.160630-1736
    PLATFORM ROLE Slate
    CONNECTED STANDBY Supported
    REPORT TIME 2016-07-3119:52:48
    Battery capacity history
    Charge capacity history of the system's batteries
    2015-12-20 - 2015-12-27 42,303 mWh 42,157 mWh
    2015-12-27 - 2016-01-03 42,331 mWh 42,157 mWh
    2016-01-03 - 2016-01-10 42,348 mWh 42,157 mWh
    2016-01-10 - 2016-01-17 41,998 mWh 42,157 mWh
    2016-01-17 - 2016-01-24 41,807 mWh 42,157 mWh
    2016-01-24 - 2016-01-31 41,887 mWh 42,157 mWh
    2016-01-31 - 2016-02-07 41,889 mWh 42,157 mWh
    2016-02-07 - 2016-02-14 41,955 mWh 42,157 mWh
    2016-02-14 - 2016-02-21 42,059 mWh 42,157 mWh
    2016-02-21 - 2016-02-28 42,195 mWh 42,157 mWh
    2016-02-28 - 2016-03-13 42,290 mWh 42,157 mWh
    2016-03-13 - 2016-03-20 42,263 mWh 42,157 mWh
    2016-03-20 - 2016-03-27 42,280 mWh 42,157 mWh
    2016-03-27 - 2016-04-03 42,253 mWh 42,157 mWh
    2016-04-03 - 2016-04-10 42,210 mWh 42,157 mWh
    2016-04-10 - 2016-04-17 42,182 mWh 42,157 mWh
    2016-04-17 - 2016-04-24 42,173 mWh 42,157 mWh
    2016-04-24 - 2016-05-01 42,112 mWh 42,157 mWh
    2016-05-01 - 2016-05-08 42,112 mWh 42,157 mWh
    2016-05-08 - 2016-05-15 42,423 mWh 42,157 mWh
    2016-05-15 - 2016-05-22 42,502 mWh 42,157 mWh
    2016-05-22 - 2016-05-29 42,206 mWh 42,157 mWh
    2016-05-29 - 2016-06-05 37,603 mWh 42,157 mWh
    2016-06-05 - 2016-06-12 34,123 mWh 42,157 mWh
    2016-06-12 - 2016-06-19 30,421 mWh 42,157 mWh
    2016-06-19 - 2016-06-26 26,354 mWh 42,157 mWh
    2016-06-26 - 2016-07-03 22,837 mWh 42,157 mWh
    2016-07-03 - 2016-07-10 18,386 mWh 42,157 mWh
    2016-07-10 - 2016-07-17 14,290 mWh 42,157 mWh
    2016-07-18 11,803 mWh 42,157 mWh
    2016-07-19 11,803 mWh 42,157 mWh
    2016-07-20 11,601 mWh 42,157 mWh
    2016-07-21 10,269 mWh 42,157 mWh
    2016-07-22 9,857 mWh 42,157 mWh
    2016-07-23 9,733 mWh 42,157 mWh
    2016-07-24 8,907 mWh 42,157 mWh
    2016-07-25 8,907 mWh 42,157 mWh
    2016-07-26 8,907 mWh 42,157 mWh
    2016-07-27 8,907 mWh 42,157 mWh
    2016-07-28 8,907 mWh 42,157 mWh
    2016-07-29 8,028 mWh 42,157 mWh
    2016-07-30 7,706 mWh 42,157 mWh
