2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-07-31T14:22:35+00:00
    I may have to do the same thing; the closest Microsoft Store is 70 miles away. I'm wondering if I do make the drive to the MS Store, will they fix the battery issue? My Surface is registered so not sure if there's anything else that needs to be done.
    How can a company that has been around as long as MS with the market impact they have create such a fiasco? Now looking at other brand tablets/laptops.
    2016-07-31T14:30:13+00:00
    I would not make the drive in hopes that they will fix it for you for free unless you are completely unable to do your work because of this issue and are prepared to pay out of pocket to have a working device. I did not find the store the least bit willing to work with me on this issue despite the fact that it had a completely dead battery barely 2 months out of warranty. I paid because I had no other option.
    If you do go, show them this thread as proof MS is aware of the issue, but I would bet they will tell you to wait for a fix or official announcement from Microsoft. Getting any money back from them after the fact will probably prove impossible.
    2016-07-31T15:01:33+00:00
    depending on the Store and who you talk to (ask for a manager) if you explain
    the situation and say you are traveling and point them at this thread and say
    you have a need to use on battery they MAY exchange for a refurb.
    Barb
    MVP-Windows and Devices for IT
    2016-07-31T15:02:02+00:00
    which store?
    Barb
