2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-07-31T10:54:59+00:00
    they are supposed to know about this and WAIVE this charge if you tell them it
    is the battery degradation issue.
    http://answers.microsoft.com/en-us/surface/forum/surfpro3-surfhardware/surface-pro-3-battery-degradation/783f6a00-19ba-4dcf-a828-0ad87751e15a
    • see Greg's post about this being possible fixed in software.
    >>It costs $99 to contact support
    Barb
    MVP-Windows and Devices for IT
    2016-07-31T12:24:09+00:00
    I have the same issue and use my Surface Pro 3 for work.
    Hopefully they will replace the batteries soon
    2016-07-31T13:48:22+00:00
    Add another user to the list. Exact same problem, started last week of May, now down to 7,600 mWh and dropping around 5% a day. Simplo battery, 290 cycles, purchased Dec 2014. I am in the IT business and have recommended the SP3 to many users. If MS does not get this resolved very quickly, this is going to be a PR nightmare and will likely result in many users and IT managers, who have been long-term supporters of MS products, starting to look for other hardware products to use and promote. We all know there will be hardware and software issues from time to time on any product, but how a company responds to the problem is the true value of a company.
    2016-07-31T14:04:57+00:00
    I continue to hope that Microsoft will actually do something for owners who have already paid out of pocket for this issue, but my experience in dealing with their customer service for this issue earlier in the year has me pretty skeptical we will ever see anything more than the barest of acknowledgement that this issue even exists. Frankly I would not be surprised if we never see another response from MS regarding this issue while they hope this thread dies quietly. It took me over a week of dealing with MS phone and email support before they could even give me a straightforward answer as to how I could even get the device replaced. I ended up driving 150 miles round trip to the nearest store which was my only option to get a replacement without sending my work computer into the black hole that is their customer service center.
